284e scanning issues - firmware numbering scheme
  • ccascott
    • Feb 2020
    • 6
    Hey,
    I have a 284e (not c284e, just the b/w one) that I'm having issues with. We are having trouble configuring both scan to SMB and scan to email.
    I captured the scan to SMB ethernet conversation, and it looks like the printer is trying to negotiate lanman 1.0 or NT LM 0.12, which are both SMB 1.0 authentication methods. Now, I know that this printer only supports SMB 2.0 in its SMB client with a firmware update, so I was thinking I would pursue this. I don't understand the KM firmware numbering schema well enough to determine if my firmware is new enough to support SMB 2.0
    The firmwares currently installed on our printer:
    Code:
    [TABLE="class: data-table-noline"]
    [TR]
    [TD="class: td-indent1"]MFP Card Version[/TD]
    [TD]A61F0Y0-F000-G00-K2(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller BOOT Program[/TD]
    [TD]A61F0Y0-1E00-G00-00(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Linux Base[/TD]
    [TD]Linux-2.6.26.8-rt16[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Kernel Program[/TD]
    [TD]A61F0Y0-1C00-G00-71[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller SubSet[/TD]
    [TD]A61F0Y0-1F00-G00-M0(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller[/TD]
    [TD]A61F0Y0-0100-G00-K2(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Operation Panel Message Data[/TD]
    [TD]A61F0Y0-8100-G00-J4[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller1[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller2[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller3[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller4[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Engine BOOT[/TD]
    [TD]A61F0Y0-0055-G00-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Scanner[/TD]
    [TD]A61F0Y0-0023-G00-10[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Printer[/TD]
    [TD]A61F0Y0-0050-G00-12[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]ADF[/TD]
    [TD]A3CE0Y0-0024-G00-10[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Finisher[/TD]
    [TD]A2YU0Y0-0071-G00-08[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]RU[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]ZU[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Panel CPU[/TD]
    [TD]A55V0Y0-8900-G60-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]DSC1[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]DSC2[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Loadable Device Driver1[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Loadable Device Driver2[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]SD[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Voice Data[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Movie Data[/TD]
    [TD]A61F0Y0-C000-G00-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Dictionary Data[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]OCR Library[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Panel Sound Data[/TD]
    [TD]A61F0Y0-C200-G00-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Thread Image Parameter[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller PIC Image Parameter[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller System[/TD]
    [TD]A61F0Y0-1000-G00-K2(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Print Controller[/TD]
    [TD]A61F0Y0-3000-GH0-44[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Print Controller Font[/TD]
    [TD]A61F0Y0-3F00-G01-40[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Print Controller Demo Page[/TD]
    [TD]A61F0Y0-3E00-G00-81[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller MIO[/TD]
    [TD]A61F0Y0-5000-G00-J4(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller PIC[/TD]
    [TD]A61F0Y0-8200-G00-31[/TD]
    [/TR]
    [/TABLE]
    Is this the appropriately up to date firmware for SMB 2.0 support?
    As for the scan to email setup, we are using office 365 hosted exchange. We have a C258 at another location that is currently both able to scan to email and scan to SMB with the same configuration settings that we have on this 284e. I've verified that all of the settings are identical, and that we aren't running into a blocked outbound port or something. I've ensured external DNS is configured properly to ensure it can resolve smtp.office365.com and I've verified the password and re-entered it several times.
    In both cases, scan to email and scan to SMB, we are getting server connection errors, for email it's error 107 and for smb it's error 535
    If I've missed some critical piece of info please let me know. I've tried more than I've listed here.
    Last edited by ccascott; 02-04-2020, 10:08 PM. Reason: Tried including packet log but couldn't because of filesize limit on txt files
  • wjurls
    • Feb 2017
    • 493
    Re: 284e scanning issues - firmware numbering scheme
    You're firmware is two years too old. (1-30-2015)
    You need level GDBM1 (8-14-2017) or newer.
    • ccascott
      • Feb 2020
      • 6
      [ATTACH=CONFIG]44812[/ATTACH]
      Super helpful, thank you. How does the numbering actually work? It seems so arbitrary
      • tsbservice
        Field tech
        • 7950
        As educated IT you already guess it, you will need newer FW.
        Sorry, wjurls beat me on that.
        • copier tech
          • 8125
          Originally posted by ccascott
          Hey,
          Code:
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [TD][/TD]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [TR]
          [/TR]
          [/TABLE]
          Hi,
          Yes your firmware is outdated to support SMB2 & most likely preventing your O365 account from sending.
          See this release note from Konica Minolta.
          Microsoft recommended the invalidation of SMB Ver1.0 in order to cope with the Ransomware (WannaCry) issues.
          Whilst the newer 'IT5" A3 Office Products (7&8 Series) support SMBv2 as standard (and even SMBv3 is available) the older 4e Series and 4 Series products only supported SMBv1. However, support for SMBv2 on these older products is now available as follows:
          Drop us an email if you need the latest firmware.
          www.copierfirmware.co.uk
          • wjurls
            • Feb 2017
            • 493
            That I couldn't tell you. Maybe one of the guru's here has some insight into the minds at KM software engineering. Anyway, all compatible firmware files will only be found in the "special firmware" tab. They quit updating the base firmware in Oct 2016.
            Lee
            • ccascott
              • Feb 2020
              • 6
              Thanks guys. I spoke to the leasing agent and he said he's going to come and update the firmware tomorrow.
              • copier tech
                • 8125
                Here's an old tech bulletin explaining the fw numbering.
                Bizhub Firmware Description Explanation.pdf
                • ccascott
                  • Feb 2020
                  • 6
                  Hey,
                  Just an update: The leasing agent came and updated the firmware, and now we are able to scan to SMB. We are still unable to scan to email, and we are getting the same error as before. I verified the settings against the ones in use in the other copier I mentioned previously, and they're the same, but it's still throwing an error 535 when you try to scan to email.
                  I'm not too worried about figuring out why that's not working because we're able to scan to SMB now. The copier guy did mention at one point that Rogers LTE Rocket Hubs have known issues with outbound SMTP traffic, but I'm able to telnet to smtp.office365.com 587 so I can objectively say the gateway isn't blocking outbound traffic on that port.
                  If you guys have any suggestions or questions that's cool. The copier guy said he lurks this forum, and he really appreciates how responsive and clever you guys are.
                  Thanks for all your help!
                  • copier tech
                    • 8125
                    Hey,
                    After updating the firmware did you update the function version?
                    • ccascott
                      • Feb 2020
                      • 6
                      I'm not sure if he did. As I understand it that would be based on the setting of soft switch 25, and it has to be set to the function version appropriate for the firmware that was installed right?
                      I'm not on site right now, so I can't find out what firmware he ultimately ended up installing, but when I find out I will post it on here so we can figure out what value that soft switch needs to be set to.
                      • Bix
                        • Apr 2018
                        • 1421
                        Yes.
                        You can access in Utility - Device information. Version 7 is corret
                        • ccascott
                          • Feb 2020
                          • 6
                          Originally posted by Bix
                          Yes.
                          I can confirm it says 7 in the device information menu.
