Konica C8000 Lower Fusing Belt Unit rebuild
  • cricketsi
    Field Tech
    • Feb 2020
    • 14
    [Misc] Konica C8000 Lower Fusing Belt Unit rebuild
    Has anyone had any success rebuilding C8000 lower fusing belt units?
    Re: Konica C8000 Lower Fusing Belt Unit rebuild
    why the need to post the same question in TWO different forums?
    you post in KM forum..
    IMHO no need to post in this one.
    • cricketsi
      Field Tech
      • Feb 2020
      • 14
      Noticed the sub-forums after this post....can't find how to delete posts. Maybe I don't have authorization to delete?
        ONLY ADMIN CAN
        pm ANEURYSM for help with that.
          • 37587
          There is a limited number of hours after you start a thread or post a reply during which you can edit or delete your post. If it still says Edit Post at the bottom right then that time has not expired.
            • 23010
            It's 8 or 10 hours. After that only the Admin can change it. =^..^=
            • sisirakj
              • Mar 2020
              • 9
              konica C 8000 lower fusing belt can rebuild successfully
              but it depends on your user belt unit present condition
              thanks
