Has anyone had any success rebuilding C8000 lower fusing belt units?
Konica C8000 Lower Fusing Belt Unit rebuild
Re: Konica C8000 Lower Fusing Belt Unit rebuild
Noticed the sub-forums after this post....can't find how to delete posts. Maybe I don't have authorization to delete?Comment
There is a limited number of hours after you start a thread or post a reply during which you can edit or delete your post. If it still says Edit Post at the bottom right then that time has not expired.Comment
It's 8 or 10 hours. After that only the Admin can change it. =^..^=If you'd like a serious answer to your request:
