Bizhub c3350 switch 5 setting for toner issue?
  • mrfuser
    • 1645
    Anyone know what the setting should be for software switch 5 to alleviate cartridge problem?
  • Synthohol
    Certified Konica Expert
    • 5944
    Re: Bizhub c3350 switch 5 setting for toner issue?
    wasnt it engine dip sw 34?
    yes engine sw 5
    4.25.5 DetailsofEachFunction-Choiceoftoneremptyrecoverymode
    (1) Use
    4 To perform the auxiliary toner replenishing sequence when the old toner cartridge is replaced after a toner-empty condition.
    4 OFF: Not performed (default)
    4 ON: Performed
    (2) Procedure
    1 Touch Service mode, -> Engine FW DipSW.
    2 Touch 5, select ON, and touch OK.
    3 Touch Close and exit from the Service Mode.
    4 Be sure to exit service mode BEFORE powering off the machine
    • mrfuser
      • 1645
      yes engine sw 5
      (1) Use
      4 ON: Performed
      (2) Procedure
