Konica Minolta accurio print C2060L error
  • bouba411
    • Feb 2020
    • 12
    [Error Code] Konica Minolta accurio print C2060L error
    Hi
    Need help please. My Konica Minolta C2060L display "ready to print" and "controller unconnected" then, not allowing to print a all.
    Any advices?
    Thanks.
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: Konica Minolta accurio print C2060L error
    web into the controller and see whats going on.
    • bouba411
      • Feb 2020
      • 12
      Since "there is no controller" we Cannot access to the machine other than by using its own display.
      • Synthohol
        • 5808
        through the network.
        same IP you print to.
        in a browser or in some cases RDC.
          • 22999
          Is the controller ON and at "00"?
          • bouba411
            • Feb 2020
            • 12
            It is an onboard controller, (ic-603), when the machine is ON the controller is ON.
            • orestesp
              • Sep 2019
              • 222
              From what blackcat4866 said, this print controller has 2 seven segment LED displays side by side somewhere on the controller (usually found on the back of the controller or on the motherboard) that indicate its status, if it's not showing "00" after a few seconds since pressing its power button, then something is wrong with it.
              I am unfamiliar with this print controller, so I can't help you locate them...
              • bouba411
                • Feb 2020
                • 12
                • orestesp
                  • Sep 2019
                  • 222
                  [ATTACH=CONFIG]44849[/ATTACH]
                  Try accessing the controller following what the manuals says: Accessing PageScope Web Connection
                  • konicavod
                    • Feb 2020
                    • 27
                    Any advices?
                    What did you do with the device before you received the message?
                    Perhaps you were flashing the firmware?
                    also take a full screen photo.
                    • tsbservice
                      Field tech
                      • 7988
                      Check that the following DIPSW is ON (1).
                      40-7: ON(1)
                      • bouba411
                        • Feb 2020
                        • 12
                        • bouba411
                          • Feb 2020
                          • 12
                          • bouba411
                            • Feb 2020
                            • 12
                            40-7: ON(1)
                            Hello,
                            Putting 40-7:ON lead to error code c-D0D1
                            • konicavod
                              • Feb 2020
                              • 27
