C364e not seeing fs534
  • Brett GS
    • Jun 2013
    • 154
    Hi all
    Sitting with an issue with a C364e.
    The machine does not see/pickup the finisher (fs534).
    I have changed the fs board,power supply and printer control board. The harness tests fine (continuity) from end to end. The fs gets the correct voltages.
    I have upgrade firmware but finisher doesnt appear when loading firmware. Not isolated in service mode.
    The ru hasnt got a board so doubt thats causing the issue.
    All pins are straight.
    Any advise?
  • tsbservice
    Field tech
    • 8081
    Re: C364e not seeing fs534
    Maybe add FS serial to machine as installed option?
    • Synthohol
      Certified Konica Expert
      • 5922
      Replace the ru
        • 23010
        You've covered a lot of ground. I'll be interested in hearing the solution. =^..^=
        • Bix
          • Apr 2018
          • 1421
          Maybe this can be useful. I have had a similar problem with a JS506. Even when updating the firmware, the MFP did not recognize this option.
          I then installed on another C364e and I updated the firmware. After re-installing the JS506 on the previous C364e, the MFP recognized the option.
          In your case, the RU that might have something has a corrupt firmware.
          • emujo2
            • Mar 2017
            • 1579
            I've seen something similar that references a s/n cut in and would say something like finisher s/n X cannot be used with machines newer than S/N X. You would not have to "enable" the finisher in service mode. I do not have the time to review all the tech bullitins regarding this so I would hope this jogs someone's memory. Have you tried a different model or different 534? E
            • Brett GS
              • Jun 2013
              • 154
              Turned out being the ru blowing the fs control board.
              • tsbservice
                Field tech
                • 8081
                Originally posted by Synthohol
                Replace the ru
                Thanks for follow-up Bret.
                This man Synthohol knows his stuff
