Scan/copy tilted to the left
  • zuckryyu
    • Jul 2019
    • 31
    [CQ] Scan/copy tilted to the left
    Konica minolta bizhub c454 ,how to make it straight
    Sent from my TA-1021 using Tapatalk
  • zuckryyu
    • Jul 2019
    • 31
    Re: Scan/copy tilted to the left
    This happen when using adf only...
    • tulintron
      • Jul 2014
      • 668
      Is your feeder DF-624 or DF-701?
      Check that it is closing properly and that there is something in the paper path obstructing it
      • copyman
        Owner / Technician
        • Sep 2005
        • 4692
        adjust screw on right hinge (standing in front of machine). The adj screw sits horizonal.
        Best to get service manual which shows proper adjustment procedure
        • tsbservice
          Field tech
          • 8010
          It's common job for a tech. Either ADF not properly adjusted or machine moved by pushing on ADF.
