Weird Cyan Lines C552
  • cayyell
    • Feb 2013
    • 85
    [CQ] Weird Cyan Lines C552
    Hi guys,
    One C552 is printing weird lines of cyan. As shown in the attachment.
    Things i have done.
    1. Swap a PH unit
    2. Swap a Relay board
    3. Swap a PRCB
    4. Swap a Cyan imaging unit
    5. Swap a transfer belt unit
    regardless the steps i have done, the demo print produces exactly same cyan lines same position same length.
    SKMBT_C55220021012260.pdf
    I am kinda loss at this moment.
  • Woxner
    • Jul 2011
    • 854
    Re: Weird Cyan Lines C552
    replace mfp or memory
      Originally posted by cayyell
      Hi guys,
      Things i have done.
      1. Swap a PH unit
      3. Swap a PRCB
      [ATTACH]44906[/ATTACH]
      I don't notice the lines UNTIL color is invoked.
      have you checked the cyan drum/dev?
      all those parts you swapped... from a used/loner machine?
      how did you diagnose unit to determine trying those other parts?
      what are the counts on imaging section parts?
      • cayyell
        • Feb 2013
        • 85
        I guess this is my last resort.
        all swap parts are used and confirmed in working conditions.
        Diagnose was confirmed not from imaging unit as it looks more like data error.
        and thank you so much for the effort to invoke the colour.
        • Zesti
          • Jun 2009
          • 311
          MFP board is the culprit. I have had problems with 552 series machines. If you continue using machine the problem will worsen with more lines. I'm already looking for a MFPB board for C552....
          • cayyell
            • Feb 2013
            • 85
            thank man, I managed to replace a MFPB yesterday. It works like charm now.
