C554e color select option missing.
  • allan
    RTFM!!
    • 5462
    [Misc] C554e color select option missing.
    Hi guys.
    Got a C554e where the color selection(auto color, full color or black) option is missing leaving a void in its place on the copy screen.
    There is a yellow dot on the application button and the color selection is missing even there.
    Its stuck in b/w.
    Tried:
    Custom display settings.
    Initialize copy program data under service mode.
    Looked to see if a custom patern was installed.
    Tried creating user account to see if it will pop up there.
    And many other things.
    Any one seen and fixed this before.
    Have not done firmware yet.
    Customer states was there one day and gone the next...
    Whatever
    Re: C554e color select option missing.
    Originally posted by allan
    Hi guys.
    Its stuck in b/w.
    Tried:
    allan,
    Brother I would try the firmware. we all are aware how quickly it can become corrupt ..
    or maybe an end user changed something and didn't admit to it (???? we all know customers NEVER do that! )
    • tsbservice
      Field tech
      • 8020
      Hi allan, check your manual for 'custom pattern'. Panel may be customized by importing custom CPD file.
      Nevermind, now I see that you checked that point. Maybe Clear All Data if possible
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        Will it actually print in color? As in, have you checked in the service mode and run color halftone test pages or the like? Also, are there any codes in memory or are any/all of the color devs or drums way past EOL?
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
        • Bix
          • Apr 2018
          • 1421
          Something similar happens when there is authentication and you set up a public user. There you can limit the printer only black and white. Alternatively, there may be a dipswitch that does this. You could try a "clear all data" but if the culprit is a dipswitch, it must be identified.
          I sent you a PM.
          • allan
            RTFM!!
            • 5462
            Yes printing is all good no problem there. Machine has 43K on it so no EOL issues.
            I sent you a PM.
            That is what i suspect its a setting on it i just can't find.
            Whatever
            • kingarthur
              • 1369
              try using the "Panel Customisation Tool", you might be able to "force" it back
              • srvctec
                • Oct 2009
                • 827
                It seems like there is a tool from KM to determine if any software switch has been changed from default. I can't remember what it's called but maybe it's only for 8 series on up as well- can't remember that either. C.R.S. is real!!
                • Bix
                  • Apr 2018
                  • 1421
                  It is an Excel file with macros.
                  If you need it I have it. I've already sent it to Allan
                  • kingarthur
                    • 1369
                    I never knew this existed, just found it on Infohub..... Many thanks
                    • Synaux
                      • Mar 2012
                      • 1224
                      I just looked in the SM for the list of software switches (dipSW) and there isn't a list?! There is a listing for Engine FW DipSW
                      I swear other models had a list of switches in the SM.
                      Does anyone have a list of switches? The only one I recall using is 65 (2mm bleed [for c654/74]).
                      • femaster
                        • May 2011
                        • 1514
                        I found it in the service manual, but I didn't see anything listed in there that would have an effect on your issue. It doesn't list what every switch does, so it may be one that isn't listed in the manual? Maybe the best thing to do would be to print the management list from another C554e (or similar model) that still has the color functionality showing on the screen, and compare it to the one from this machine. There is a full list of switch settings printed out in the management list. Perhaps you can find an entry that differs between the 2 and fix your issue that way.
                        I tried to copy and paste the switch settings into my post, but the board complained there was too many lines. Since you have a copy of the manual, the switch settings are in Section I-12.15.6.
