Has anyone replaced the standard hdd with the new ssd harddrives
  • larweedad
    • 93
    Has anyone tried to replace the standard hdd with the new ssd drives on the e to 8 series copiers? We tried but get get an error of fa14. If we get into the service mode to run a logic format, It stays at 0% and never changes. Not sure if we should try Physical format on the ssd or what.
  • allan
    RTFM!!
    • 5462
    Re: Has anyone replaced the standard hdd with the new ssd harddrives
    Wonder if the SATA driver and firmware will allow for this.
    Whatever
    • qbert69
      • Mar 2013
      • 1152
      What Brand of SSD? Most copiers run a *nix (Linux/Unix) flavor of Operating System. You might check to see if that SSD has been tested & spec'd to run natively with a *nix OS!!! I know that there is a company that sells Apple upgrade parts, Apple Mac Upgrades - RAM, SSD Flash, External Drives and More Mac OS X is a *nix system and Macsales has their SSD'S rated to work with Apple Hardware. You might need to dig a little deeper for compatibility information!!![emoji41][emoji1303]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • copier tech
        • 8202
        • Synaux
          • Mar 2012
          • 1224
          I don't really know much about the cx58s but I do know about HDDs.
          In theory it should work as long as you have the correct partitions tables set, and I am almost sure you will need to the Physical Format first either way. I don't know what the HDD sizes are, but you might have to utilize a partition editor to make a partition the exact size as the 8 series (in case KM but some sort of HDD size checking in place for some reason).
          I always thought that if I needed to I could always upgrade the HDD on older machines, but I have always had extras and honestly haven't had many HDD failures that I couldn't fix, so I never tried it.
          • larweedad
            • 93
            It was worth a try and thanks for the responses
            • Bix
              • Apr 2018
              • 1421
              Do you have real advantages with an SSD on a multifunction printer? The operating system is integrated into the card so I don't think there are speeds in the startup. Maybe when doing voluminous scans or using the user box but I usually haven't noticed any particular differences.
              What do you think? Let me know your opinions
              • Synaux
                • Mar 2012
                • 1224
                I have wondered the same. I am not sure if the bottleneck is the HDD, but a c650 with the IC-409 (no SSD) will run circles around c654s with no Fiery especially on large pdf scans/prints. Given the age discrepancy, there should be no excuse for this and what more annoying is the IC-409 is really not that powerful of a computer.
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  My whole reasoning of the idea for this SSD swap of a failed HDD (I work with @larweedad) was from a standpoint of price and mechanical reliability, in addition to possibly faster scans to the HDD or even prints when ripped to the HDD. Our service manager gets HDDs for about $90.00 already formatted properly for specific machines. If we could use SSD's in place of spinning HDD's, one can get a brand name 256GB SSD for around $50.00. Then all we would have to do would be to properly format the new drives. But what we discovered was that there are 11 partitions for the 4e series HDDs after performing a physical format, followed by a logical format. Since mechanical failures of spinning HDD's are relatively rare, I'm not sure the effort to try and make SSD's usable is worth it. And the whole SATA controller F/W compatibility thing is also a consideration.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • qbert69
                    • Mar 2013
                    • 1152
                    Your computing device, regardless of operating system, is only as fast as the slowest component bottle necking the data chain!!![emoji15]...so yes, a SSD (no moving parts) is a definite consideration for upgrading!!![emoji6][emoji1303]
                    • Synaux
                      • Mar 2012
                      • 1224
                      11 partitions?! ffs Konica...
                      Anyways, I never tried cloning a disk with that many partitions, but should be possible to automate.
                      I actually want to try this now
                      • srvctec
                        • Oct 2009
                        • 827
                        I know!! 11 partitions is ridiculous.
                        The only ones I've messed with are the HDD's on the C253 series. We kept having multiple failures at a customer that had HORRIFIC power problems and wouldn't fix it. So, they kept calling saying their machine was locked up and the issue was always a corrupted HDD. After paying for more than one (they had a contract but we paid for the first couple replacements), I started formatting their corrupted drives exactly like what the C253 would format it from the machine but it was just three partitions. I would do the format on a windows PC. Then we would just keep one on hand and swap it out, reformat the corrupt one, repeat. I was hoping the newer machines would be similar.
                        Let us know how it goes when you try it!!
                        • Synaux
                          • Mar 2012
                          • 1224
                          Yeah I cannot think of good a reason for so many. I want to try it, but I am not going out of my way to do it either.
                          Very technically a SSD has moving states so does have moving parts
                          Anyways, it is fairly common knowledge that HDDs have been the slowest component of just about any computer system for some time. The problem is that I just said a MFP with no SSD (albeit a slow Fiery) outperforms a more modern MFP with a significantly faster HDD (i.e., sata interface). In fine, yes is it an upgrade. Will it make a noticeable difference: I'm not so sure.
                          • qbert69
                            • Mar 2013
                            • 1152
                            It's a usual practice for copy machine OS installs, most are Linux, to create multiple partitions to sandbox storage space for various reasons/ functions, then that partition when it is finished being used for whatever purpose can be securely erased.[emoji41]
                            • Synthohol
                              Certified Konica Expert
                              • 5892
                              about 20 of my HDDs are from copiers, i take them home and delete endless partitions then make a single one and backup kids pics, documents and movies and store it on a shelf for disaster recovery.
