Firmware KONIKA MINOLTA BIZHUB C220
  • avecosat
    • Jun 2012
    • 305
    #16
    Re: Firmware KONIKA MINOLTA BIZHUB C220
    I will change the clutch is cheap and not too much work .
    • Nico.FRA
      • Mar 2020
      • 38
      #17
      "I founded it's in the main drive section, I haven't really founded out how to access it, suppose i have to search in the back of the machine, behind the mainbord?
      • Synthohol
        Certified Konica Expert
        • 5864
        #18
        Originally posted by Nico.FRA
        "Here it is, test pages, the black is just gray. Original toner inside, tested with two new toner catridges!"
        [ATTACH]45135[/ATTACH][ATTACH]45136[/ATTACH]
        Just to ask and I'm not trying to give you a hard time but changing toner bottles is a complete waste of time unless you run 500 copies with the new bottle.
        The sub hopper holds a supply of toner to the dv unit and the bottle merely refills the sub hopper.
        This takes quite a bit of copies to circulate new oem toner into the dv unit.
        I also don't understand a drive solenoid having to do with light copies.
        Clean the laser glass, run a toner add cycle or two and reset and stabilize then run all the gradations. (3xeach) and reprint the gradient pattern and look for change.
        Also clean the idc sensors under the belt.
        Let us know.
        • Nico.FRA
          • Mar 2020
          • 38
          #19
          Let us know.
          " Thank you for the advice of this manipulation. unfortunately, that did not change anything, I stay with a black .... which is not black :-("
            so you replaced the main board due to CQ/PQ problems? hav you replace the PCU and cleaned and checked all HV contacts?
            start with the inexpensive parts first... sounds like you are 'shot gunning' the troubleshooting process.
            • tsbservice
              Field tech
              • 8031
              #21
              What value is K TCR level?
              • Nico.FRA
                • Mar 2020
                • 38
                #22
                I'm going to look to replace the PCU and go around the connections"I'm going to look to replace the PCU and go around the connections
                • Nico.FRA
                  • Mar 2020
                  • 38
                  #23
                  "4% while the K toner is full, this for about 5 months"4% while the toner is new, this for about 5 months4% while the toner is new, this for about 5 months"4% while the toner is new, this for about 5 months
                  • Nico.FRA
                    • Mar 2020
                    • 38
                    #24
                    "Hello, I launched an impression and filmed the behavior of the clutch, it seems to work normally. Watch the video folowing this link: https://photos.app.goo.gl/EA6rehyDB3fpsQvK6."
                    • avecosat
                      • Jun 2012
                      • 305
                      #25
                      Maybe the first step is to tray in service mode to get a good level toner K in the unit and then make the imaging adjust
                      • Nico.FRA
                        • Mar 2020
                        • 38
                        #26
                        "By imaging process adjustment, i did two times a manual toner ad for the black, after that, going into test mode for a gradiant patern for the black......still so bad!"
                        • avecosat
                          • Jun 2012
                          • 305
                          #27
                          If you make a test for MYC the quality is good ? is only with the black ?
                          • Nico.FRA
                            • Mar 2020
                            • 38
                            #28
                            "Yes, just the black, but what remains strange is that, at the very beginning of the problem, I had changed the K development unit and that the prints had returned to normal, very good quality, from the first impression, then, a month later, the quality of black is dimmed to make only gray."
