Firmware KONIKA MINOLTA BIZHUB C220
  • Nico.FRA
    • Mar 2020
    • 38
    [Dead] Firmware KONIKA MINOLTA BIZHUB C220
    Hi, i just changed the main power board on my Bizhub C200.....but missing the Firmware. Is anybody here to help me?
    Thank's a lot!
  • GIUBOSS
    • 1382
    Re: Firmware KONIKA MINOLTA BIZHUB C220
    I don't think it is essential to do the firmware update after replacing the power supply board unless you have found serious problems
    • tsbservice
      Field tech
      • 7911
      Some members at CTN may be more kindly disposed to Contributors.
      How to Contribute?
      Here
      • Nico.FRA
        • Mar 2020
        • 38
        "The machine displayed Error 164 !"
        • emujo2
          • Mar 2017
          • 1580
          Well you need to double check your post..Is it a C200 or C220, and did you replace the main board or the power supply board.. If memory serves the C360 would not work in a C280 or C220, and if you have C280 firmware loaded then put it in a C220 you would get the 164 error code. If this is the case then f/w would corrrect this. E
          I was off a little C220 is its own board, C280/C360 use same board
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Thank's a lot!
            Firmware isn't load onto the power supply
            Regards Mark
            • Nico.FRA
              • Mar 2020
              • 38
              "Thank you for this answer, You're right! First, this is the C220, not C200, and this is the main board. But I'm afraid that the problem will not be resolved anyway, even if the card is correctly installed. Indeed, the first problem, the one for which I thought that the motherboard could be responsible, is a problem of fixing the black color and an ink level indicator which does not react when a new toner is installed. I also changed the development unit K, but that only corrected the problem that a hundred copies to become again in pale copy on black."
              • Nico.FRA
                • Mar 2020
                • 38
                "no, you are right"
                • Nico.FRA
                  • Mar 2020
                  • 38
                  <br>
                  "no, you are right"
                  • avecosat
                    • Jun 2012
                    • 303
                    The problem is not the unit is the selenoid, that is why you change the unit and a few prints the toner down .
                    • Nico.FRA
                      • Mar 2020
                      • 38
                      "Hi, thank's for your answer, i had inverted the yellow solenoid with the black by modifying the chips and only the black continues to not work (while it uses the yellow solenoid). Error code: P-9"
                      • avecosat
                        • Jun 2012
                        • 303
                        • Nico.FRA
                          • Mar 2020
                          • 38
                          "Really? "
                          • avecosat
                            • Jun 2012
                            • 303
                            Could you upload an image of what your problem is?
                            • Nico.FRA
                              • Mar 2020
                              • 38
                              "Here it is, test pages, the black is just gray. Original toner inside, tested with two new toner catridges!"
                              SKMBT_C22020030318140.pdfSKMBT_C22020030318141.pdf
