BH-C-25, service: 0094
  • Hansoon
    • Sep 2007
    • 3297
    BH-C-25, machine is in very remote location, haven't seen it yet myself but the customer claims that the machine never comes to ready state. It throws a code "service: 0094" as soon as it does the pre-drive during start up. This goes accompanied with a continious weak klicking sound coming from the vertical section in the right door. Anyone seen this before? Any hints please before I go there?
    Thanks in advance.
    Hans
    " Sent from my Intel 80286 using MS-DOS 2.0 "
  • Synthohol
    Certified Konica Expert
    • 5463
    Re: BH-C-25, service: 0094
    you can either replace the transfer belt or follow this doc.
    (replacing it is much easier)
    • Hansoon
      • Sep 2007
      • 3297
      Thanks!
      Is it really "only" the transferband?
      Than I could send the chap a replacement by Parcel Post.
      Not neccessary to travel to the end of the civilized world...
      Hans
      • Synthohol
        • 5463
        usually.
        machine is way old though, even my service manual is from 2011.
        maybe time to upgrade?
        • Hansoon
          • Sep 2007
          • 3297
          Its a rental making good money every month.
          Part of a large contract with several machines.......
          Hans
          • jwai
            • May 2018
            • 497
            Hans
            check the transfer belt shutter solenoid and gears on 2nd transfer unit.
            • dave w
              • Jun 2015
              • 230
              0094 = Image transfer pressure/retraction failure.
              Check the solenoid as i find that it sticks to the rubber buffer.
              • allan
                RTFM!!
                • 5445
                Thanks!
                Hans
                Looking at that repair procedure its on the machine and a bit of care needs to be taken to get the job done.
                Never new it had that issue. Normally a problem on the door side with a plastic stud breaking.
                My advice would be to take a door in case.
                Whatever
                • Synaux
                  • Mar 2012
                  • 1224
                  Funny how so many documents from KM can be super vague, but this document literally shows us how to do end-user level tasks...
                  • Hansoon
                    • Sep 2007
                    • 3297
                    The paper synchronization solenioud buried in that vertical door? I mean to remember that it is totally out of plastic without the dreaded foam damper or am I confused?
                    Hans
                    • copier tech
                      • 7934
                      ^This is the fix seen it a loads of times you can just pick off the tiny pad they go sticky & hold the solenoid closed.^
                      • Hansoon
                        • Sep 2007
                        • 3297
                        Hoping not sounding too stupid but are we talking about pos. #25 on page 14 of the parts manual - the SD2?
                        Tried to find the location of that solenoid in a junker machine in our store but could not find it. OK, light was bad, will try again by daylight.....
                        Hans
                        • copier tech
                          • 7934
                          Hans
                          I just looked on a C35 manual & yes item 25 is the solenoid and item 23 looks like the pad you need to remove or replace.
                          • dave w
                            • Jun 2015
                            • 230
                            The solenoid rubber buffer
                            It gets sticky and stops the solenoid for returning back, I have removed alot of these in the passed and never a recall. does the trick.
                            Just a fiddly job.
                            • Hansoon
                              • Sep 2007
                              • 3297
                              Well, went there. Changing the TB didn't change the situation. Than I had a look at the sync solenoid but could not find any sticky pad nor rubber buffer. (see picture below) to me there is no such sticky whatsoever in this BH-C-25 machine. I reseated the solenoid connector and after reassembling the beast, it worked from itself.......
                              Very unsatisfying not to know what have happened.
                              Thanks anyway for your help guys.
                              Hans
