I want to help at Stop the alarm, Orange light : bizhub C754
  • mhmds102466
    • Jul 2019
    • 74
    [Misc] I want to help at Stop the alarm, Orange light : bizhub C754
    I want to help at
    Stop the alarm
    The orange light always lights up with the message Replace Staple Cartridge
  • allan
    RTFM!!
    • 5462
    Re: I want to help at Stop the alarm, Orange light : bizhub C754
    Install staples?
    Or fool the sensor.
    Whatever
    • mhmds102466
      • Jul 2019
      • 74
      Originally posted by allan
      Install staples?
      Or fool the sensor.
      How do I do fool the sensor
      • allan
        RTFM!!
        • 5462
        Pure cunning and mad skill.
        Believe its a switch..
        Cut a piece of cold drink can and shove it in there. Make sure it can not reach the front otherwise it will jam the stapler.
        Never done this before so you are experiment case no1.
        What about unplugging the LED if its bothering them so much?
        Whatever
        • rrrohan
          • Sep 2011
          • 1977
          Or trouble isolate the staple?
          Sent from my Nokia 7 plus using Tapatalk
          • allan
            RTFM!!
            • 5462
            Believe it will still be red and tel you you can't use stapler?
            Whatever
            • Bix
              • Apr 2018
              • 1421
              CE - System 1 - Problem unit isolation set - page 2 - Staple: SET
              I believe this could solve the problem, what do you think of it?
              • femaster
                • May 2011
                • 1514
                You will still have the orange error light, except the message will change from replace staple cartridge to staple can not be used now.
                • femaster
                  • May 2011
                  • 1514
                  Originally posted by mhmds102466
                  I want to help at
                  Stop the alarm
                  At first, I agreed with allan completely. However, after looking at the theory of operation for the stapler, I realized that it isn't going to be as easy as fooling the empty sensor. There are actually two sensors in the stapler unit that would need to be fooled, and neither is going to be an easy task. Your best bet would be to just have them buy some staples.
                  If you want to proceed with your attempt, I've attached the section from the service manual that shows how the stapler empty sensing works. There is the empty sensor, and then there is the self priming sensor. Both of these would need to be "fooled" as they operate in unison. If the empty sensor is fooled, them the stapler is going to cycle multiple times every time a door is opened and closed, or the unit comes out of sleep, boots up, or at every job, because the copier will be trying to prime the stapler, which will never succeed because there are no staples to prime it with. While I don't know for certain, this may also lead to a SC-error.
                  Good luck if you attempt it!
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4718
                    What finisher? Why not just repair or replace it instead of "rigging" it? All my wholesalers have many of these finishers they will give you for free or maybe $25. When they ship containers full of copiers to other countries they don't want the finishers so wholesalers end up scrapping them.
                    Replace the whole finisher or just the staple unit.
                    I have the FS-534 complete staple unit if you want. Will sell cheap. Also have the staple units for the SD-511 booklet option if needed.
                    • tsbservice
                      Field tech
                      • 8020
                      Good job femaster. After looking at pdf I think if one remove staple cartridge and 2 springs from sensor actuators(last picture) machine will think everything is OK with staple.
                      • allan
                        RTFM!!
                        • 5462
                        Ok scratch that idea.
                        Just get some staples.
                        Whatever
