Bizhub C220, does not recognize new black toner, pale black copy
Re: Bizhub C220, does not recognize new black toner, pale black copy
Ok then tweak it to see if that helps.
Set the TCR K offset to +3 then do toner add followed by gradation adjustment.
For the fun of it reinstall the devtank could be a bad developer bias contact but with a low TCR value i doubt it.WhateverComment
My bad, then don't think its available to adjust on the C220.
So you say you have removed the developer tank and added some toner by hand in there.
Never more than a teaspoon at a time?
Guess you are frustrated by now. Wonder if the dev tanks the techs replaced was new or used?WhateverComment
Guess you are frustrated by now. Wonder if the dev tanks the techs replaced was new or used?Comment
Ok so you have 2 copiers a C200 and a C220?
You need to get a trained tech out there to sort you out.
Seem like things are going from bad to worse.
So something changed and then the printing stopped. Can you identify that?
Demo and other internal print made from the machine ok?
What if you print from a USB thumb drive?
In the job log on the machine do you see "deleted due to error"?WhateverComment
In the job log on the machine do you see "deleted due to error"?Comment
Checked this tread just now and was feeling sorry for Nico....
It's a pitty...
Nico a last try...
Clean your laser windows with the cleaning stick inside of the front door....
Try replacing the ITB... IMAGE TRANSFER BELT if you have 2 machines........
I'm assuming your TCR level is above 6% which quite fine....
Where did you get the new unit...from KonicaMinolta or from Alibaba????????Comment
NO one asked you to leave. I'm not the admin and don't have the authority to ask anyone to leave. I'm not being cruel. If you were near me I would come and out and try and fix it for FREE! That's the type of person I am. Just that you are at a point you need to have a "qualified" tech take care of your issues. Sounds like you called a big company that always tries to upgrade the customer once they see you have an older model. They are like sharks!
You need to find an "independent" tech / small company that is like most on this forum and takes pride in "repairing" machines not to sell you right away. I understand there are cimcumstances where someone might be in a remote area and that's where it can be a challenge. Perhaps put an ad in local paper for an independent tech needed or even post to see if Tech on this forum might be in your area/country? Hopefully you can get these issues resolved and can come back here for successful help with a different issue in the future. At that point it would be nice to see you are a contributer but will still get help here regardless.
Once again sorry if I came off the wrong way but it comes to a point that just can't be resolved online.
Best of luck!Comment
Nico is not a technician and maybe he does not understand that these machines sometimes the problems are very complex and you need professional experience to understand other professionals who are trying to help you.Comment
Best of luck!
NicolasComment
It's a pitty...
Nico a last try...
"Thank you so much Allan for all your advice, I will leave the site. Unfortunately, the technicians I am brushing up on do not give me the solution and I actually had a lot more interest from you than from the people I paid to do it here in Montpellier. As Copyman asks me, I will therefore disappear. for information, the Minolta technician who came by yesterday did not help me out but sent me a proposal to buy the machine for € 400 and then offered me the sale of another machine for € 4,350 ..... not judging the interesting troubleshooting. It's to vomit!I apologize for the time you have lost for me and the considerable energy in the service of a stranger. Yours sincerely. Cordially. Nicolas."
Do this on my own free time so i don't mind helping guys who try, believe in the right to repair these machines.
Don't give up yet. Its a pity you can't find a decent tech around there. There are good secondhand finds out there.
Trick there is to find a machine that just came from contract and the PM condition is good.
Then only would it be a good buy.
But continue to repair the machines you have.
Probably a simple problem one of use can repair in less than 30min.
Curious about the total count on the machine?WhateverComment
It's a pitty...
Nico a last try...
Sometimes the simple things that gets overlooked.
Could be a soiled laser glass.
Otherwise a bad bias voltage connection to the dev tank.WhateverComment
