Bizhub 4050 email jam notification?
  • Toxic
    • 698
    Have few of 4050 leased and set email notification but when i received jam notification it only shows "paper jam", time and ip.
    This is not realy helpful without jam code.
    Somebody know how to set up to receive specific jam code in email?
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: Bizhub 4050 email jam notification?
    use vcare.
    • tsbservice
      Field tech
      • 8020
      Originally posted by Synthohol
      use vcare.
      Vcare in Europe CSRC is paid service if you're not KM direct. I don't think that it deserves in therms of setup and fee especially for that small old model.
      Toxic I also think for normal scenario email notifications are sufficient but honestly I don't think that this Lexmark's rebadges have anything more to add.
      Atleast quick look at SM didn't show a clue.
      Take care bud.
      • Toxic
        • 698
        You are right tsbservice, i dont have need for more than basic reporting over email.
        I also search SM for some dipsw but cant find it and does not seems logic that options does not exist but who knows what Lexmark thinking.
        This way how it works it is almost useless to know there is some kind of jam and can not know what is exact code.
        • tsbservice
          Field tech
          • 8020
          I do setup our office C250i to send email notifications and upon making a jam( don't blame me usually I remove paper jams :. ) this is what I received:
          Misfeed detected.
          Nice work KM. Totally useless that way, have to agree.
          • Toxic
            • 698
            Same thing like on 4050,just misfeed,no code?
            • tsbservice
              Field tech
              • 8020
              Yes, just message - Misfeed detected. No code.
              • Toxic
                • 698
                I assume you try to change jam code display in service mode-system 2-jam code display-display ?
                • tsbservice
                  Field tech
                  • 8020
                  Yes of course... I may be Bizhub line newbie.
                  But I do my courses...still lack of experience in KM.
                  Not lack of ever reading the Manuals though.
                  • allan
                    RTFM!!
                    • 5462
                    That would be switch 11 bit 7 on real KM machines. That would display the J-XXXX code on the screen.
                    Is that available on a 4050? Even then would it add that info on the email body?
                    Most reported jams are from the DF's when customers do silly things. Email jam reports are a bit much.
                    Whatever
                    • Toxic
                      • 698
                      In my case MFP show jam code on machine display but not send report which code is.
                      Same thing with service call code,today i received just info to prepare for phonecall from customer
                      Printer Name: KONICA MINOLTA bizhub 4050 Serial Number: A6VF0210xxxx Error Message: "Service Call"
                      Time: 2020/03/19 11:53:22
                      • allan
                        RTFM!!
                        • 5462
                        Wonder if KM made there own A4 based machines if they would be any good.
                        These Lexmark machines with there ever failing IU's and crap KM OEM toner cost a lot to keep.
                        Then there is Kyo that just runs over the competition with there far superior A4 machines.
                        Whatever
                        • tsbservice
                          Field tech
                          • 8020
                          On 4050 I believe it will always display jam code. On newer models like bizhub C224e ie it's under System 2 --> Jam code display --> Display/Do Not Display
                          • Jumping Jack Flash
                            • Jul 2009
                            • 66
                            KM BH4050 configured in CSRC as Email2 sends jam codes, so it should also send them in email notifications.
                            I know that you can set the number of consecutive jams after which the device will send notification of the jam,
                            so with the code should not have a problem.
                            The topic is interesting, I will try to check it carefully.
                            • allan
                              RTFM!!
                              • 5462
                              Its an easy firmware fix i guess.
                              Need to escalate the problem thru the right channels to see if they will fix this.
                              Whatever
