c300i screen freezed
  • Genotrom
    • Feb 2020
    • 77
    Hello, how are you? Here in france we are having a big problem with coronavirus but for now we are fighting.
    I have a problem with a bizhub C300i. i installed it a month ago and it had G00-45 firmware. The first time it was turned on, the printer was loading and the screen went blank. Strange, but it can happen. After several minutes, I turned it off and on again. It finally started and I installed the G00-75 for safety.after a month, it is now giving trouble. It took a long time to wake up this morning but after a while it started working. This afternoon it started to crash again. It remains in the loading process.
    Even after unplugging and hanging up the power plug.
    I have seen that there is a new firmware, surely I will try to update it but I would like to listen to your advice.
    That first problematic ignition makes me think about a more serious problem
  • copyrooks
    • Oct 2013
    • 210
    Re: c300i screen freezed
    Do you have bizhub secure installed? There is a software update to fix the startup issues where it would take up to 9 minutes to boot up even after sleep mode. G00-79 firmware was released to fix that long boot up time. There is also another update that come out less than a month after g00-79 which is g00-7b that fixes another issue with freezing. Give em a shot, my experience with the updates is that there is still random slowness and freezing so I wouldn't say it's completely gone but i guess eventually Konica will find a fix. I'm not a fan of these i series but that's my opinion and i hear lots of techs in other areas feel the same.
    • jwai
      • May 2018
      • 508
      Yup, the long start up time is the weak point.
      • gere1
        • Oct 2018
        • 20
        as copyrooks says the g00-7b is supposed to fix these problems
        and 2 or 3 more serious things
        they have to be for konica to send us an email to update goo-7b
        • Synthohol
          Certified Konica Expert
          • 5840
          you need to disable marketplace.
          • Genotrom
            • Feb 2020
            • 77
            hello people, I tried to start the printer but without success. Continue to get stuck at 30% during boot. i have also tried to rewrite the firmware but something goes wrong with the MFP Controller. It gives me back: NG. He manages to update the scanner and the rest. So now I don't know whether to start replacing the SSDB or CPUB.
            • copyrooks
              • Oct 2013
              • 210
              I had that exact issue on a c250i, konica gave me a tar reset file that didn't resolve the issue. Ended up replacing the memory board and that resolved the issue.
              • Synthohol
                • 5840
                you can try this, wont hurt to try.
                If firmware fails on the MFP controller section perform the following steps
                1. Power down machine and unplug from the wall
                2. Remove the CPU and Storage board from the base board and let it sit outside of the machine for 10 minutes
                3. Reinstall CPU and Storage board
                4. Load latest base firmware , but instead of holding the top button in the back of the operation panel hold down the bottom button. This will take you to the screen calibration which will need to be completed and the firmware screen will appear after it is completed.
                5. Load MFP controller firmware only.
                • tsbservice
                  Field tech
                  • 8019
                  First thing to start with is doing boot diagnosis as per SM. From there you can pinpoint possible source/s of failure.
                  • Genotrom
                    • Feb 2020
                    • 77
                    actually i forgot to do a self diagnosis. In the past on a c360i I have already replaced SSDB. Apparently some models have defective SSDBs. The code is the same but in the Part List you can see a change. I will try to change it and I will let you know.
                    • tsbservice
                      Field tech
                      • 8019
                      Technically here KM call it Storage board (STRGB).
                      Stuck loading at about 25% means mostly problem with CPU board(LPDDR4).
                      • Genotrom
                        • Feb 2020
                        • 77
                        That's right, STRGB is the most correct name! thank you for your support.
                        Can I know where you managed to find this information?
                        • tsbservice
                          Field tech
                          • 8019
                          Did you do boot diagnosis? What are results?
                          • Bix
                            • Apr 2018
                            • 1421
                            hi, try self diagnostic before
                            • Genotrom
                              • Feb 2020
                              • 77
                              hi, I thank you for your advice. i haven't done the self diagnostic yet because I'm waiting for the order from the CPUB and STRB to arrive. the customer is in an area infected with Coronavirus, so I can't be in that area for a long time. im preparing with all possible solutions to get the printer back, in this way I prepare myself for any unexpected. Here in france we are very worried about coronavirus
