BH C284e Counter list/ list output shrunk, squashed, condensed
  • D Colour
    • Oct 2008
    • 213
    [CQ] BH C284e Counter list/ list output shrunk, squashed, condensed
    Hi
    Have a strange issue on a C284e.
    When we print a counter out or anything from list output we get the below. It has squashed or shrunk the image down.
    Long edge Feed
    Short Edge Feed
    They do seem to print out much slower than normal.
    This is an A3 counter list
    Print & copy jobs are fine. The demo page & configuration page are also fine.
    Firmware was the latest (M1). Tried reinstalling it and MFP reset.
    Any suggestions?
    Everything that has a beginning, has an end.....
  • tsbservice
    Field tech
    • 8016
    Re: BH C284e Counter list/ list output shrunk, squashed, condensed
    Latest base G20-M1 or special GDN-M1? The reason I'm asking is because there is a good 3 years time difference between them.
    Maybe worth to try newer FW version if on G20-M1. Also what about consumables page and internal prints in CE mode?
    I would run also full diagnostic, just in case. Maybe reseat Memory/s.
    In any case I'm interested in your findings.
    Good luck.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4706
      Wow! That is a new one and really strange. I've never seen it but will check the Kon/Min knowledge base for you later today (unless you have access to it and looked already)?
      • D Colour
        • Oct 2008
        • 213
        Good luck.
        Its G20-M1. Was always warned off using the "Special" firmwares! Consumable page prints out the same (squashed), as does the maintenance, parameters etc.
        In Service>Test mode, they all print out as normally!
        One of the other engineers ran the diagnostics which all came back ok.
        Will try reseating memory.
        Thanks for the help!
        • D Colour
          • Oct 2008
          • 213
          We are an Olivetti dealer, have access to Olivetti's side of things. Plenty of bulletins, but nothing relevant to this!
          If you could have a look, that would be great, thanks!
          • tsbservice
            Field tech
            • 8016
            I've already tried. Nothing came up. Did you try to print list from bypass tray? It's interesting because it moves image differently main/sub scan according to paper size.
            • D Colour
              • Oct 2008
              • 213
              Just tried that, all exactly the same as feeding from the paper trays.
              • Andysnave
                • Jul 2018
                • 5
                Yes came acroos this the other day on a C754e. Tried firmware, plus reseating memory, etc. This baby throws up a CE-004 code as well. Only when you print the counter list. Very odd.
                • allan
                  RTFM!!
                  • 5462
                  Also had this but could not fix this as this had no real effect on the contract i just ignore it.
                  Whatever
                  • gere1
                    • Oct 2018
                    • 20
                    already happened to me in some equipment I tried all the firmware so far
                    until I did an initialization-clear all data did not recover
                    I don't know what it is, but it worked
                    • tsbservice
                      Field tech
                      • 8016
                      Maybe just some corrupt data
                      • minoltahack
                        Hi
                        Long edge Feed
                        [ATTACH=CONFIG]45291[/ATTACH]
                        Short Edge Feed
                        [ATTACH=CONFIG]45292[/ATTACH]
                        [ATTACH=CONFIG]45293[/ATTACH]
                        Any suggestions?
                        Hy Change is laser unit.
                        • pepper38_cnd
                          Field Service Manager
                          • Aug 2005
                          • 1075
                          I had this exact issue. The solution is to do a full system clear. Do not back up anything ie: address book or settings, because importing them again after the system clear will recreate the issue. Al data will have to be reentered.
                          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                          Now into Ip TV KODI Boxes
                          • rrrohan
                            • Sep 2011
                            • 1977
                            i had kinda similar issue with faxes reducing from A4 to A5.
                            like the above said when in doubt just system clear everything, how ever in my case i re imported the address book from a CSV without and problem but i re did the network settings manually so maybe its just restoring the admin data that reintroduces the problem?
                            • Synaux
                              • Mar 2012
                              • 1224
                              This is your one and only post and you.... lol just lol
