Replacing the 4 series MFPB and PRCB
  • copyman
    Owner / Technician
    • Sep 2005
    • 4654
    A lot of posts about this.
    See attached. Hope this helps.
  • copier tech
    • 8133
    Re: Replacing the 4 series MFPB and PRCB
    Thanks, I wasn't aware of the DIP SW.
    • tsbservice
      Field tech
      • 8000
      This DIP SW only applies to certain part numbers MFPBs, not all is my understanding.
      • ivovb
        • 695
        Thank You for information, but... it is not absolutelly true. Ass usually KM does not provide the whole info...
        I have already managed to exchange an MFP board from one machine to another. Allmost one year working fine. No issues.
        Procedure is different when old MFPB is used instead of new. After exchanging the boards first step is to use beloved ressssset tool. And latest firmware after that. Thats it (if I remmeber well).
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4654
          BR
          Of course they want to sell you a new board. You can swap one board at a time for troubleshooting purposes and I have also swap the MFP board and left in machine but always used the SSD from the original machine with bad board and had no issues.
          The most important thing is not to swap both MFP, PRCB or even the SSD boards at same time. This is where it can get tricky
          • ivovb
            • 695
            Exactly. I've just save it for a moment... ;-)
            BR
            • tsbservice
              Field tech
              • 8000
              BR
              What about machine counter. Did the counter follow donnor MFPB. In example - machine A dead(counter 1000), replace MFPB from machine B(counter 2000), machine A is now working but counter become 2000.
              • ivovb
                • 695
                SSD has leading part - so we get finally 1000.
                BR
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4654
                  I believe the total counters & serial numbers are kept several different places on K/M copiers, MFB, SSD,Control panel pwb and maybe one more place. Think Blackcat posted this as well.
                  Like I posted I've swapped MFP board successfully a few times, if I recall the counters did NOT carry over and still had the original counters including the life counters from machine that needed the MFP pwb.
