Cant scan to email. TX Errors bizhub C224
  • suprastan
    • Mar 2020
    • 2
    Using Gmail, getting TX errors when sending. Currently on version: I assume I need to update this firmware. Does anyone have the last firmware for this and instructions on how to install since there is no Update firmware anywhere in the admin menu.
    Any help would be greatly appreciated..
  • copyman
    Owner / Technician
    • Sep 2005
    • 4788
    Re: Cant scan to email. TX Errors bizhub C224
    Your are correct. There is a firmware addressing this issue.
    Please make a small contribution to this website and someone or myself will send it to you.
    • suprastan
      • Mar 2020
      • 2
      Just made one.. I am so happy I found this place, I am new to the copytech world, so I will need you guys for the long run
      • copyman
        Owner / Technician
        • Sep 2005
        • 4788
        Thanks for contributing
        PM me your email and i will send right away.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4788
          Just sent you latest FW. That should be all you need since you said in PM your issue was gmail. There is also special FW for office 365 scan issues. Not sure if that is included in the latest FW.
          See attached doc
          • allan
            RTFM!!
            • 5462
            Have seen that some thing simple like choosing start TLS insted of SSL would allow it to work.
            Sure you know to allow less secure apps.
            Whatever
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Out of interest - this model is basically unsupported in my country soon and they stopped releasing firmware for it ages ago. What is the latest that is really available ?
              • tsbservice
                Field tech
                • 8081
                No base FWs from 2014. Latest special FW for C224 I believe is GBN-M0 from 2018.
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  Very friggen interesting.
                  Do you know if it supports sha2 like the e series ?
                  • Jumping Jack Flash
                    • Jul 2009
                    • 66
                    There is a software solution from 04.2016 Try it
                    Symptom
                    MFP fails to send e-mail if Office365 server or Gmail server is used as SMTP server.
                    SMTP server : smtp.gmail.com
                    SMTP port : 465(SSL) or 587(TLS)
                    SSL/TLS : SMTP over SSL or Start TLS
                    C224/C284/C364/C454/C554/C654/C754, bh654/bh754
                    Cause
                    Gmail server and Office365 server changed SSL certificate from SHA-1 to SHA-2.
                    MFP mentioned above do not support SHA-2 certificates, and therefore, fail to send e-mail if using these server as SMTP server.
                    Even if using other SMTP server which has SHA-2 certificates for SSL, MFP fails to send e-mail.
                    Solution
                    MIF Version up firmware has SHA-2 certificate support and can send e-mail even if using Gmail server or office 365 server as SMTP server.
                    GAx - A9/E4/G9/J6/K0/K1/K2/K5/K6/K7
                    GBx - A9/E4/G9/J6/K0/K1/K2/K5/K6/K7 (Web Browser)
                    Gxx - 83 (for LK-114)
                    Things to be aware of when using MIF version up firmware
                    Update procedure of this FW is different from the procedure of standard firmware.
                    Printer driver, voice data, movie data and so on should be updated.
                    Please be sure to read release note for MIF version up firmware when using the firmware
                    We will release new MIF version up firmware which improved above 2 issues at beginning of February, 2016.
                      • 30573
                      You can also use the non Sal gmail port 25 with no authentication. Can send to gmail accounts only
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4788
                        I've been in touch with the original poster and after sending him F/W, bulletins, etc I told him his only options may be SMB or the dreaded FTP scanning. He decided to go with SMB and it's working great!
                        • tsbservice
                          Field tech
                          • 8081
                          Symptom
                          Cause
                          Solution
                          Try what JJF propose.
                          • copier tech
                            • 8236
                            If you have the C224 (Non e model) you'll need to install the 'version up firmware'
                            Version Up Firmware Technical Information Rev4.pdf
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              I see the version up firmware officially supports LK-110
                              Interestingly, since my home machine is a c284 I tried a spare LK-110 I extracted from a parts machine and it installed fine on the c284 using LMS.
                              This explains it.
                              I guess prior to this version up firmware being available they would not have allowed it based on the serial number.
                              It works but it simply acts as if LK-102 & LK-105 are installed but the fancy exclusive additional features of LK-110 naturally arent there with the stock c284 fw.
                              Also, LK-101 v3 is practically useless on the old 4 series now as most websites that even display say this browser wont be supported much longer and pretty much everything else gives constant ssl errors. These are the classic symptoms of a near end of life browser.
