Approved USB drives for Kon/Min
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Found this helpful. Hope it helps someone else.
  • copier tech
    • 8202
    Re: Approved USB drives for Kon/Min
    Thanks.
    Do you have an updated list for new models, this is very old?
    • tsbservice
      Field tech
      • 8053
      Thanks.
      From 4e series and up including latest i series recommended an tested with the latest Base/Special firmware are:
      -TRANSCEND 16GB JetFlash 700 USB 3.1 Flash Drive (TS16GJF700)
      -TRANSCEND 8GB JetFlash 700 USB 3.1 Flash Drive (TS8GJF700)
      I use first one of them, no issues.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4765
        [QUOTE=copier tech;1383751]Thanks.
        I've been posting stuff from my saved docs. Will see if any newer lists on K/M dealer website.
        • allan
          RTFM!!
          • 5462
          Between Kingston and and Sandisk i never had issues if the one don't work the other does.
          Whatever
          • copyman
            Owner / Technician
            • Sep 2005
            • 4765
            Thanks.
            Didn't see anything else. If I come across I will post. Agree with allan. Sandisk 4-8GB has worked great for me.
            • mascan42
              • Oct 2008
              • 485
              I've never had an issue with anything 16GB and lower as long as I format it before each use. On rare occasion, I've had to remove the formatting entirely, and then format it again (format to NTFS, then back to FAT32).
