Biz i series troubleshooting guide
  • copyman
    Owner / Technician
    • Sep 2005
    • 4828
    Hope this helps
  • allan
    RTFM!!
    • 5462
    Re: Biz i series troubleshooting guide
    Great finally they noticed the fix for the paper feed units. Will probably get more than 150K out of the rollers.
    Even it this means a different pickup, feed and separation roller.
    Sure this will work on older models too.
    Whatever
    • copier tech
      • 8275
      Originally posted by copyman
      Hope this helps
      Thanks for sharing!
      โ€‹
      • avecosat
        • Jun 2012
        • 305
        Thanks for the information
        • copyman
          Owner / Technician
          • Sep 2005
          • 4828
          Yes, finally some good improvements. Wonder how much these new rollers are going to cost, $20 - $30 each? Lol
          Speaking of rollers, I've had good results with using aftermarket from Copylite & Katun, Use the ribbed & red feed from copylite and the katun red feed for sep. The copylite red has same tacky feel as OEM the katun isn't as tacky so better for sep. Been getting at least 100k with this combination. I found if you use same red (oem or generic) for feed & sep they wear in less than 50k
          • rrrohan
            • Sep 2011
            • 1977
            i thought we always had different rollers. to be honest i only use the a00j563600 red ones but do recall back in the day use to be asked to use the blue ones for longer life.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4828
              The 5636 rollers wear faster when used as feed and sep. Doesn't matter with pick up because not rubbing against another roller. And like I posted I have been using the ribbed for P/U instead of the red with much better results!
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Hope this helps
                Thank you
                Regards Mark
                • marvin_PL
                  • Jun 2012
                  • 24
                  Any part number of new rollers?
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4828
                    Ribbed P/U: A64J564201
                    New style Feed: A64J564101
                    New style Sep: AA2J560000
                    • konicatoshiba
                      • Jan 2023
                      • 33
                      Hope this helps
                      MANY THANKS!
