konica minolta di 2510 abort code
  • Shesman
    • Apr 2020
    • 2
    [Error Code] konica minolta di 2510 abort code
    Pls. Whenever I turn on the the machine to make photocopy, the following error code is displayed. Code = 0x00dc0003.tsk name= tRT 22601.tsk id = 0x00005849.Sp = 0x85f45580ra = 0x80c734f8.build_1347.040705.Solution pls. Thanks
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: konica minolta di 2510 abort code
    here is the abort code list, that dinosaur machine is 17 years old. it cost more to fix than just buying one from this century
    good luck.
    • tsbservice
      Field tech
      • 8009
      good luck.
      Although I'm with you on this machine being too old and tricky to keep alive, we should be aware that some people especially in poor countries have no resources, nor money and must work on what have in hand. Lagos in Nigeria seem to be one of them.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4684
        Think Di-251 is similar and remember getting abort codes if exp lamp foil had cracks in it. Been awhile think we used solder to fill in cracks.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4684
          These older models are "state of the art" in poor countries.
          • Shesman
            • Apr 2020
            • 2
            Thanks. But do u have the firmware?
            • allan
              RTFM!!
              • 5462
              As per that abort code list it point to a scanner system failure.
              So not a firmware issue i would guess. Did you replace boards on it?
              First i would reseat the main board and connectors.
              And as mentioned check the scanner lamp.
              Sure there are plenty of B363 type machines around there. What would that cost you?
              I sell and service machines for a couple of Nigerians in Durban ZA.
              Know how to run small shops around here and how to make some cash were the locals are clueless.
              Whatever
