SD-512 Folds correctly but when combined with stapling the fold is off
  • Gaffers01
    • May 2011
    • 335
    #16
    I know this is an OOOOLLLLLLDDDDD post but did you manage to fix this? as i'm having the exact same issue
    • Tech09
      • Apr 2020
      • 145
      #17
      The gripper shaft on the stopper can pop out of position. On the attachment, look at #6, that shaft with both grippers on seats into a holder on both sides.
      • Ziggy
        • Feb 2018
        • 764
        #18
        I had the same thing happing and replacing the paddle wheels fixed it. Items 22&23 pictures attached
        This gallery has 2 photos.
        • Gaffers01
          • May 2011
          • 335
          #19
          Ok ill check both of these and hopefully get it fixed.
          • laserline
            • Jan 2025
            • 1
            #20
            Alternative Solution!!!
            We had a tech come out from Pacific Automation to work on the unit as it was doing the same thing but even had pushed the fold askew a bit. The tech did a cleaning all around on various rollers and found it would only jam when stapling the booklet but as w/out stapling it folded 100% okay. The tech didn't have any more time to stay and had to get going, letting us know he would be back at a later date. So this morning knowing it was something to do with the staples pulled the staple cartridges and found one had a jammed staple in it. We removed it, cleaned the staple cartridge holder and put them back in. They ran several test prints and SUCCESS! Problem Solved!
