printing on "never tear" paper with konica minolta bizhub press c7000
  • buzzerbeater
    • Jul 2025
    Hello everyone.
    Does anyone know if it is possible to print on never tear paper using konica minolta bizzhub press c7000? Is there maybe a similar material/paper as never tear paper that could be printed with that machine?
    We need 2600 pieces of small "signs" with vegetables printed on it that will be placed amongst planted vegetables on bed/patch in greenhouse. So they need to be some kind of waterproof and they must not be to "soft" so they can be planted in earth easily. Has anyone already produced some kind of those small signs with vegetables? Any suggestions what material to use?
    I found some kind of synthetic paper - Monotex L 360g that looks promissing... Can this paper be used on the machine mentioned above?
    I will be very thankful for any suggestions and opinions.
    Have a nice day
    • 23008
    Re: printing on "never tear" paper with konica minolta bizhub press c7000
    What about transparencies? Just don't duplex them. =^..^=
      • 30216
      Used No tear paper in past many years ago. Usually you have to set the paper type a thick or heavy in order to bond onto the paper.
      Look at the gram weight and recommend paper type setting
      Good Luck
      • FrohnB
        • Jul 2017
        • 1919
        Omertà
        • NeoMatrix
          Senior Tech.
          • 3513
          Buy a hand held label printer... Many fonts personal designs...
