Engine Firmware to c3350
  • kmuserpl
    • Mar 2020
    • 2
    Hello.
    I looking for latest ENGINE firmware version to KM bizhub c3350.
    Thank for help.
  • GIUBOSS
    • 1437
    Re: Engine Firmware to c3350
    welcome, are you a technician and have the service manual? What's wrong with the machine?
    • Tommy D
      • Jun 2020
      • 9
      New to the service. This forum is great!
      I have two bizhub C3350 systems. One machine powers up with blank touch screen and does not appear on the network. After power cycling again, the machine boots up correctly with active touch screen and works correctly for copy, scan and print. The second power cycle works every time. I'm hoping a firmware upgrade would resolve the issue.
      The firmware versions:
      Controller F/W A3GN30G0142-999
      Engine F/W A3GN0Y00050G001000
      Boot F/W A3GN99G0100-999
      Panel F/W A3GN02G0152-999
      Fax F/W A6ED40G0400-999
      Scanner F/W A3GN23G0102-99
      The Boot, Panel, Fax and Scanner F/W is the same as the other machine that operates correctly but the Controller and Engine F/W looks like older versions. Is there a way I can get a download of the updated firmware?
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Firmware should only be available to credited km service engineers if you been trained by km or develop you should have access
        Regards Mark
        • tsbservice
          Field tech
          • 8035
          Firmware isn't panacea. Better call certified KM tech who can diagnose and troubleshoot your problems.
          • Tommy D
            • Jun 2020
            • 9
            Thanks for the feedback! That's my goal on a shoe string
