Konica Minolta C300i - excessive toner consumption
  • DiVallelunga_Makhymo
    • May 2017
    • 10
    hi, we have a Konica Minolta C300i under repair, the MFP has less than 30,000 pages and has already changed 6 black toners, 2 for each color and as many toner boxes. Do you have any idea why this excessive toner consumption?
    P.s I updated the sign to version G00-79.
    Thanks.
  • tsbservice
    Field tech
    • 8020
    Re: Konica Minolta C300i - excessive toner consumption
    Never seen nor hear this.
    Drums erase led strips working? CQ problems?
    Obviously for some reason toner is going in WTB abnormally fast.
    Bad high voltage pcb also come in mind.
    Good luck and please definitely post outcome here.
    • Bix
      • Apr 2018
      • 1421
      Hi, I advise you to view the voltage values within the Service Mode.
      • emujo2
        • Mar 2017
        • 1579
        you should be getting 28 k per bottle..based on 8x11 1 sided, 6% fill. Enable the coverage counter detail and run for some time period ..Check to see if your toner coverage is in excess of 30 -35%..E
        • Haaland
          • Mar 2009
          • 20
          Any solution on this one? customer of mine is reporting the same problem.
          • Bix
            • Apr 2018
            • 1421
            Hi, have you updated the firmware to G00-B6?
            At what level is the TCR?
            What have you already analyzed / replaced?
            • Haaland
              • Mar 2009
              • 20
              Just arrived, firmware is 7B, and will be updated now.
              TCR is between 4.7 and 4.8 at color and 6.03 at black.
              Manual is saying between 4 and 7% should be okay for black
              Table No. is also at spec.
              • Bix
                • Apr 2018
                • 1421
                There is something wrong with the TCR. It should be about 6%. If I'm not wrong, you can add toner in the service mode. In the technical course I was suggested to do an image stability initialization and to perform calibration until TCR rises to 6%.
                • Haaland
                  • Mar 2009
                  • 20
                  I forgot to mention, unlike DiVallelunga_Makhymo, this machine is only having problem with black toner, so im not so worried about the colors.
                  but i will try do a image stability initialization, just in case.
                  • copier tech
                    • 8165
                    There have been a few bulletins for this model, your issue may relate to the one below. Basically they've added a new toner agitation feature.
                    i series toner aggitation.pdf
                    โ€‹
                    • tsbservice
                      Field tech
                      • 8020
                      [ATTACH]47610[/ATTACH]
                      This isn't for C300i series. Anyway Haaland didn't mention machine model so we can only guess.
                      • tsbservice
                        Field tech
                        • 8020
                        What model? Those color TCRs are too low for C300i series.
                        Should be:
                        5.5% (black) 4.0%-7.0%
                        6.5% (magenta) 5.0%-8.0%
                        7.0% (cyan/yellow) 5.5%-8.5%
                        The only TCR value within specs is black.
                        โ€‹Any anomalies on test prints?
                        • Haaland
                          • Mar 2009
                          • 20
                          No issue with print quality, and yes, its a C300i-sieres, or a C250i to be specific.
                          What i did earlier today was to take out the HV-board and check all the connections, and also clean them with alcohol, as well as the connectors between the machine and drums.
                          I know there has been some issues similar on the C3350i and most of the time on that model it was enough to clean connectors.
                          Customer is informed and will contact me if they need a new toner after short time, too bad they just replaced the black toner, so it might take a while.
                          My plan B i to replace the HV-board.
                          I will also compare the TCR with another machine tomorrow morning, i have a feeling that this is HV-related and not TCR, but i cant know for sure.
                          EDIT:
                          Machine is also connected to CSRC, today the counter was at 6600 copies, i will probably check the counter in csrc after a while and then visit them and check the toner, if the toner is only half full after 1000 copies, i know the issue is not solved.
                          • tsbservice
                            Field tech
                            • 8020
                            EDIT:
                            Have them to save "empty" toners. Are they really empty or machine has another problem and just false report toner empty and tricks customers to change over and over full cartridges.
                            Print MML list and upload here. What about WTB? This quantity toner cannot disappear just like that. It must be in WTB or in 'empty' cartridges.
                            • Haaland
                              • Mar 2009
                              • 20
                              I did export the MML to usb before i left, i can check when i get back to the office tomorrow.
                              Most of the time toner is ordered by the machine it self via csrc, i can also check how many toner and WTB that we have sent them.
