Bizhub 368e - internal error occured
  • nelo
    • Apr 2019
    • 32
    Hi All, mentioned model throws error message every time a network print is made or even printing the config page or demo page.
    Machine can copy, print meter count and print machine reports from the service mode. Self diagnostics test done and is all good.
    HDD and RAM tested working. New firmware uploaded and still the same error message when printing from network or printing the config page / demo page.
    I am suspecting a printer controller board issue or ssd issue.
    If anyone came across similar fault can point me in the right direction.
    Regards
    NELO
  • tsbservice
    Field tech
    • 8020
    Re: Bizhub 368e - internal error occured
    Prior boards I will do Initialization on network settings in service mode and maybe Clear All Data.
    • Bix
      • Apr 2018
      • 1421
      Hi are you a technician?
      The first thing to do is to try and find the error code. The printer does not return any codes to you because after rebooting it manages to work properly.
      To view the list of codes, access the Service Mode and in the history section check the error codes.
      It could be a sync error between cards. We are waiting for your news.
      • emujo2
        • Mar 2017
        • 1579
        This is failrly common error solved by installing the latest firmware..machine will be fine until any print job (even internal) is sent..Seen it at least 1/2 dozen times. E
        • byronf
          Senior Member
          • Sep 2017
          • 109
          Regards
          NELO
          Hi
          Service Mode - System 2 - internal error auto cancel - set Rank B and Rank C to off. This will display the error code and you can troubleshoot from there.
          • tsbservice
            Field tech
            • 8020
            Hmm maybe I overlooked this, he said new FW is updated but that doesn't mean necessarily latest.
            • nelo
              • Apr 2019
              • 32
              Hello, yes, I checked error codes but none. I even printed the machines management list to see if a error code did show but still nothing.
              Regards
              • nelo
                • Apr 2019
                • 32
                Hi, did this today after reading your reply. Error still remains.
                Regards
                • nelo
                  • Apr 2019
                  • 32
                  Originally posted by byronf
                  Hi
                  Hi and thanks for the reply. Will try this to observe error code.
                  Regards
                  • nelo
                    • Apr 2019
                    • 32
                    Firmware uploaded is 01FW_AA6V0Y0-F000-GC2-X4.exe ( GC2-X4 ) May you confirm if it's the latset?
                    Regards
                    • tsbservice
                      Field tech
                      • 8020
                      Regards
                      Yes it is latest. Did you do switch 25 B0 hex after update and reboot the machine?
                      • Bix
                        • Apr 2018
                        • 1421
                        Regards
                        Hi, is there any news after disabling the automatic restart of the error? Theoretically the MFP should stop restarting.
                        • Synthohol
                          Certified Konica Expert
                          • 5849
                          the code should be listed in history in CE.
                          • tsbservice
                            Field tech
                            • 8020
                            The System Error code will be logged in the S1 portion of the Machine Management List. Use USB and open S1.csv on your PC, scroll down to the service call history.
                            • emujo2
                              • Mar 2017
                              • 1579
                              Regards
                              Version G00-X4 is the latest..GC2 X4 is a special f/w..E
