Bizhub 368e - internal error occured
  • Bix
    • Apr 2018
    • 1421
    #16
    Re: Bizhub 368e - internal error occured
    Originally posted by emujo2
    Version G00-X4 is the latest..GC2 X4 is a special f/w..E
    GC2-X4 is a bugfix firmware that also includes special changes that will be included in the next firmware.
    G00-X8 will be released soon, but it should only solve a security problem.
    • Albonline
      • Sep 2008
      • 1144
      #17
      try formatting the hdd physical, then logical.reinstall firmware and movie data after.
      • Synthohol
        Certified Konica Expert
        • 5807
        #18
        we dont even know what the error code is so before taking drastic measures how about we just get the darn code from history before jumping into formatting anything.
        • Albonline
          • Sep 2008
          • 1144
          #19
          because i've had this problem on the 8 series units many times. usually after firmware flash or bizhub secure set up. hdd format and reload fixes it most of the time. have had to format the emmc on a couple.
          • nelo
            • Apr 2019
            • 32
            #20
            Hi All I was able to fix the fault by replacing the NVRAM with firmware upload.
            Regards
            • Synthohol
              • 5807
              #21
              Thanks for the follow-up post.
              Glad you got it sorted.
              • tsbservice
                Field tech
                • 7986
                #22
                Regards
                Thanks for the feedback. By NVRAM did you mean eMMC board? Also what was error code?
