C284e yellow almost missing
  • mrfuser
    • 1604
    We have a client with a c284e that the yellow is almost missing on, the color is super washed out. We replaced the iu and transfer belt and toner is oem and same result. Sensor reads about 7 , same as other colors. Cleaned idc sensors and same result . Any thoughts?
    also replaced yellow dv unit a while back. Seemed to work ok after that. Maybe bad toner pump is not getting enough into developer?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4591
    Re: C284e yellow almost missing
    Why did you replace the yellow Dev unit awhile back? If it was because it dumped did you replace the yellow drum at same time? There is no toner pump on Kon/Min like Ricoh has.
    If I was to guess I would say the yellow dev dumped again. This time make sure you replace drum at same time. Also it's been mentioned on this forum many times, ANY over life drum can cause ANY developer unit to dump. So check all your consumables.
    Very easy to troubleshoot, run a yellow halftone test page, if you have diagonal white streaks it dumped. Or you can physically look at mag roller on dev and see developer powder missing on mag roller.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Try replacing with new oem pcu and dev assy this happens when some engineers rebuild and rechip assy's
      Regards Mark
      • mrfuser
        • 1604
