Bizhub c451 jams from tray 1 and tray 2
  • rightbrained
    • Oct 2014
    • 40
    [Jamming] Bizhub c451 jams from tray 1 and tray 2
    I recently picked up a Bizhub c451 to use at home. I knew when I bought it that it jams from tray 1 and tray 2. Some online searches suggests that there are bad sensors in these drawers. I currently only print from the bypass tray or the deep drawer.
    Is there a source for these sensors and is there a step by step replacement tutorial or schematic somewhere online?
    My background: I live in a town of 700 people and I am able to offer cheap copy service to my fellow townsfolk ONLY because I pick up used machines off Craigslist, etc. and do repair work myself. Although I am not a tech, I've been doing this for over 15 years and have been pretty successful thus far.
  • tsbservice
    Field tech
    • 8001
    Re: Bizhub c451 jams from tray 1 and tray 2
    Review this thread.
    konica C550 code 1101
    You may aslo find helpful SM which someone here may send you.
    • femaster
      • May 2011
      • 1492
      It really depends on what the symptoms are (never feeds a single page, feeds 5 pages then jams, etc.), and what the jam codes are. On that model, I'm pretty sure the default was to NOT show jam codes when a jam happens, unfortunately. Try running something from each tray, and if it shows the code (which will look like: J##-##) post it back here noting which tray produced which code. Without the code(s), it's just a guessing game.
      On a side note, sensors rarely fail. More likely you have an issue with worn feed tires, slipping one-way bearing(s), feed clutche(s), etc. It's not impossible that it's a sensor, just improbable.
      • tsbservice
        Field tech
        • 8001
        I really enjoy reading your posts. Great thinking man.
        • femaster
          • May 2011
          • 1492
          I'm assuming that is a compliment...? I hope.
          • tsbservice
            Field tech
            • 8001
            Not once in the past(not here) I've made opinion for people based on what and how they write. Later I met some of them personally and now they're my friends
