Konica minolta "i" series freezing up.
  • pickle8486
    • Aug 2013
    • 26
    ok so I got an i series c360i that is periodically freezing up. So far I have done all the normal steps of initializing, and running the 8 series reset tool. It is currently at 7b firmware that did load 100%. These machines seem to be a good idea, but KM needs to go back to the drawing board on the software side.
  • Albonline
    • Sep 2008
    • 1153
    Re: Konica minolta "i" series freezing up.
    turn off all unneeded services/ apps. especially marketplace. may want to try putting unit into debug mode.
    • Albonline
      • Sep 2008
      • 1153
      have seen the emmc board, (m2 ssd ) cause erratic hard stops on this line, I have been fdisking them and recovering the copier afterward. good luck.
      • copier tech
        • 8200
        Whats the best way to completely remove marketplace?
        • tsbservice
          Field tech
          • 8053
          Delete this c.rap with old openAPI remove program.
          • Albonline
            • Sep 2008
            • 1153
            there is a dip switch setting to disable it. and then turn off screensaver.
            • Albonline
              • Sep 2008
              • 1153
              like this solution better , but i'm a direct employee. rules rule here.
              • copier tech
                • 8200
                Found this post. No mention of a SW to disable it completely.
                bizhub i-series hide the pre-installed MarketPlace Application
                • tsbservice
                  Field tech
                  • 8053
                  That would hide it but won't remove it. Like Albonline said or via openAPI remover.
                  • Albonline
                    • Sep 2008
                    • 1153
                    (172 to 01) keep it under your hat!
                    • tsbservice
                      Field tech
                      • 8053
                      Oh Thanks. I know it but just use other way. No at all KM employe...they simply may want me
                      • Bix
                        • Apr 2018
                        • 1421
                        Marketplace never bothered me.
                        The iSeries have 8GB of RAM, so it should be able to run many applications without crashing if optimized.
                        In my case, it's always been the bloody STRGB. Here are some cases that the replacement of the STRGB (storage board) solved:
                        - C250i printer goes offline continuously, even by setting all the network parameters correctly.
                        - C250i the screen freezes randomly.
                        - C300i no longer turns on and the screen remains white.
                        Konica Minolta will hardly admit that the problem is that (they often say it is CPUB or Firmware problem). I managed to pass it under warranty always because I had the demonstration that by replacing that, the C250i / C300i has started working again.
                        • Bix
                          • Apr 2018
                          • 1421
                          However they are SSD M2, if you have a motherboard in your PC you can use them again and have a faster computer.
                          • Albonline
                            • Sep 2008
                            • 1153
                            make that 04
                            • Albonline
                              • Sep 2008
                              • 1153
                              try clearing a partitions on the ssd and do a system recovery. i have done this a few times without further returns on the unit.
