C4801 Helpp
  • furius
    • Jan 2018
    • 34
    C4801 Helpp
    Hi guys I have a serious problem with a machine in the lab
    It would be fantastic if you could help me.
    I have a working C364 machine from which I took the pcrb (pwb) card then mounted on a customer's C284.
    The c284 registered the updated c4802 so I followed the procedure and managed to start it.
    In the meantime I have tried two more cards(pwb) on my C364 machine
    But I always get error C4801.
    I have another working C284 that I could use but I'm afraid to make more messes.
    Could I be able to solve by reassembling the old pcrb currently mounted on the customer's machine?
    thank you very much
  • GIUBOSS
    • 1391
    • Synthohol
      Certified Konica Expert
      • 5805
      Re: C4801 Helpp
      and make sure the 2 digit hex is correct for the machine type because you put it in a different model.
      when you boot to a firmware stick hit machine type on the screen and make sure its not FF. or for the previous model it was in.
      thats mainly a MFPB thing but never hurts to make sure.
      • tulintron
        • Jul 2014
        • 669
        Re: C4801 Helpp
        You need another C364 in operation
        Firmware
        correct plate replacement procedure
        Correct hexadecimal for the printer
        risk of loss of some data
