C658 vs C759
  • progoffice
    • Nov 2008
    • 337
    C658 vs C759
    We have a potential new customer that is looking for a high speed Konica Minolta color machine. We have several C458/C558 machines in the field and those do pretty good for both us and the customer. I realize the C658 is in that same family; however, the C759 has more of the older heavy duty Konica design with imaging units instead of separate drum/DV units. For those that have worked on both models, which model do you prefer in both serviceability and reliability?
  • progoffice
    • Nov 2008
    • 337
    Re: C658 vs C759
    I guess I should really ask C650i vs C759. We haven't messed with the new i series yet, but all I read on here is that there are quite a few bugs to still be worked out those new models.
    • Albonline
      • Sep 2008
      • 1153
      Re: C658 vs C759
      759s run well in high volume environments, the inversion/delivery systems will need regular attention, but they are worth the effort. if it's for occasional use / convenience type of unit i would go 658. if you can get one.(not in manufacture any longer), i would stay away from the faster i series units till the firmware bugs are fixed.
      • progoffice
        • Nov 2008
        • 337
        Re: C658 vs C759
        Thanks Albonline. That's kind of what I thought. Forgive my ignorance on this model (C759), but does it use something different than C654e/C754e models? I'm not familiar with your term inversion/delivery system.
        • Albonline
          • Sep 2008
          • 1153
          Re: C658 vs C759
          basically the duplex unit, and everything on the door wears out faster than the say 754 one way roller down on the right side gets torn up . stuff that was designed for 45 page a minute running at 75 pages isn't going to last.
          • copier tech
            • 8188
            Re: C658 vs C759
            • tsbservice
              Field tech
              • 8029
              Re: C658 vs C759
              At 60k a month they seems to me underutilized. A C458 would load that monthly volume as well for some years.
              • CompyTech
                Super Tech
                • Feb 2011
                • 706
                Re: C658 vs C759
                In a nutshell:
                C759 = C754e beefed up
                C658 = C554e beefed up
                C650i = C658 with the new i Series interface.
                • progoffice
                  • Nov 2008
                  • 337
                  Re: C658 vs C759
                  Thank you all for your posts. One thing I love about the C454e/C458/C558 is they are so much easier to move than those back busting tanks like the C452/C754e and still the C759 I assume. It's amazing how they could run as good or better and weigh half as much. I still think that once the bugs were worked out of the "e" series machines up to the C554e they became one of the best color machines of all time. I would say the same about the 8 series if they didn't change the drums.
                  • tsbservice
                    Field tech
                    • 8029
                    Re: C658 vs C759
                    I like your opinion but technically they changed charge units not drums. 4e vs 8, low volume up to 554e.
                    • progoffice
                      • Nov 2008
                      • 337
                      Re: C658 vs C759
                      You got me on that, but I was referring to the charge mechanism of the drum like you mentioned. It seems like a roller would cost more to make, but I guess not if people have to buy more drums. Those older style drums would last sometimes 2.5 times their yield or more. What does the i series use?
                      • tsbservice
                        Field tech
                        • 8029
                        Re: C658 vs C759
                        No more corona/scorotron/wire chargers due less ozone requirements. Cheep like small printer PCRs exposing drums.
                        • Bix
                          • Apr 2018
                          • 1421
                          Re: C658 vs C759
                          In the C650i series the drums last longer (theoretically). But it is mainly due to less amount of toner in my opinion.
