Step by step F/W KMB 754
  • SEESOD TECH
    • Jun 2020
    • 4
    hello,community
    i had a problem to firmware KMB 754
    because when i connect usb flash drive to device
    screen appear error external memory
    tell me please,
    step by step to firmware konica 754
    thank you very much in advance
  • Synthohol
    Certified Konica Expert
    • 5735
    Re: Step by step F/W KMB 754
    USB must be no bigger than a 4Gb drive
    the correct files and folders must reside on the root of the drive.
    use the service port.
    • escalante
      • Sep 2018
      • 115
      That is the procedure to update the firmware by means of a usb memoryScreenshot_20200603-093849_OneDrive.jpgScreenshot_20200603-093913_OneDrive.jpgScreenshot_20200603-093932_OneDrive.jpgScreenshot_20200603-093951_OneDrive.jpgScreenshot_20200603-094005_OneDrive.jpgScreenshot_20200603-094017_OneDrive.jpg
      Enviado desde mi SM-J701M mediante Tapatalk
      • SEESOD TECH
        • Jun 2020
        • 4
        How important is this F/W version ?
        If the model is incorrect Will cause the device to display error external memory screen?
        thank you,sir
        • rrrohan
          • Sep 2011
          • 1977
          ive been using 16GB memory for years without problems
            thank you,sir
            what do you think?
            can you put a Chevy v8 in a pinto?
            • Synthohol
              • 5735
              hey Phil, people always find a way LOL...
                Ok brother .. bad analogy.
                • SEESOD TECH
                  • Jun 2020
                  • 4
                  what do you think?
                  i meant,
                  we can use latest firmware ver. or use recent fw ver to pcb board
                  • tsbservice
                    Field tech
                    • 7910
                    Ha-ha smart one you are
                    People ALWAYS will find a ways for crazy things.
                    • tsbservice
                      Field tech
                      • 7910
                      i meant,
                      What sort of problem/s you have? Why do you think it's FW related?
                      • SEESOD TECH
                        • Jun 2020
                        • 4
                        When turn on the device and put usb to service
                        screen is appear error external memory,
                        because the firmware incorrect maybe right?
                        thank you for your replies
                        • tsbservice
                          Field tech
                          • 7910
                          Follow exactly the steps escalante show you. Also you are supposed first to connect USB and then turn on the machine.
                          Try it also with front door open.
                          • Albonline
                            • Sep 2008
                            • 1131
                            if you are trying to put a used prcb in this , you WILL get that message.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              you can tell Life Stop was disabled on that car
