bizhub C308 quality problem
  • Genotrom
    • Feb 2020
    • 77
    Hi, I have a bizhub c308 with 130k. This printer has started making spots at the bottom of the page. Of course I have to change the black drum but before going, being a restricted area, I wanted some advice from you.thankyou
    qualitè.pdf
  • copier tech
    • 8144
    Re: bizhub C308 quality problem
    [ATTACH]45835[/ATTACH]
    Your image isn't very clear Most likely the black drum. But I would also take a transfer unit with you when you go back.
    • tsbservice
      Field tech
      • 8010
      Originally posted by harigabi
      Hi!
      It's definetly the black drum unit. Replace it and it will be okay
      Agree, 130k is good counter.
        • 23007
        96 mm interval? Yes, black drum. Typical at 130K or even much less. =^..^=
        • Walterj
          KONICA MINOLTA
          • Jun 2017
          • 89
          [ATTACH] 45835 [/ ATTACH] [/ QUOTE]
          Replaces the DRUM UNIT (DR-313K)
          Exactly that mistake is due to wear on the drum and black charge roller.
          Follow the installation and adjustment steps in the service manual.
          Regards.
          • Bix
            • Apr 2018
            • 1421
            Hello, often changed the drum and I solved it.
            • Genotrom
              • Feb 2020
              • 77
              thank you guys!
              Yes, I have resolved with DRUM_K
