Bizhub C253 Magenta/Black Stripes across the page
    • 23009
    #16
    Re: Bizhub C253 Magenta/Black Stripes across the page
    Originally posted by Fretek
    So I guess all I can do now is to order a new transfer belt unit with the Nr A02ER73022, is this correct?
    Correct. You'll need to do a color calibration after it's installed. =^..^=
    • Fretek
      • Jun 2020
      • 5
      #17
      To conclude this, I replaced the transfer belt unit and did a graduation adjust and it's working perfectly again.
      Thanks alot to everyone who helped! Highly appreciated.
      • qbert69
        • Mar 2013
        • 1152
        #18
        Just a note for future reference...
        If the cleaning blade on the ITB have the "chatter" marks for more than one color and they're blurred, you can be darn sure the problem is occurring with the ITB cleaning section!!! One way to check is open the side door during mid-process image transfer to see if the "skid marks" are visible. Additionally to completely rule out that the transfer belt unit doesn't need to be replaced, is to take out the ITB unit, run a thin piece of mylar plastic under the silicone cleaning blade to dislodge any clumped toner or paper dust and re-powder the belt with some yellow toner dust. Even before you do this procedure, you will want to inspect the belt for any lines, divots or indentations. [emoji41][emoji1303]
        Sent from my SM-N950U1 using Tapatalk
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
