Bizhub C250 E-mail RX function, how to get it to work?
  • HasseM
    • Jun 2020
    • 5
    I noticed an EMail RX setting under the network settings. I tried filling in my POP servers address and login details but nothing happens. I would like to have my bizhub receive emails and print the attachments..... Does anyone know how to get this to work? Anyone got it working at all?
  • qbert69
    • Mar 2013
    • 1152
    Re: Bizhub C250 E-mail RX function, how to get it to work?
    Last firmware update for that MFP was in 2010!!![emoji15] Ten Fricken Years Ago!!! Good Luck getting that working as security protocols have gotten tighter and more strict since 2010!!![emoji57]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5848
      you cannot have a copier receive an email and print an attachment to that email.
      thats not how it works.
      besides, copiers dont have spam filters so hope you have an endless supply of paper to keep filling the trays
      pop will print the email only, even on current models. no copier that im aware of will open an attachment, decide what format that attachment is and print it.
      sorry but thats is way too much to ask of that dinosaur let alone a new model.
        +1
        • emujo2
          • Mar 2017
          • 1579
          Although the C250 does not support this, any new MFP that allows the use of the LK110 v2 allows printing email attachments from POP server. And you all are correct, I don't even think the C250 supported authentication..E
          E-mail RX Print is a function that prints a file attached to the E-mail received by the machine.
          If you send an E-mail to the E-mail address of the machine, you can print a PDF, Compact PDF, JPEG, TIFF, XPS, Compact XPS, OOXML (.docx/.xlsx/.pptx), or PPML (.ppml/.vdx/.zip) file on the computer using the machine without using the printer driver.
          When using the E-mail RX Print function, follow the below procedure to configure the settings.
          To use this function, the optional Extension Memory and i-Option LK-110 v2 are required. bizhub C658/C558/C458 provides Extension Memory as standard.
          1. Configure settings for connecting to the network such as setting of the IP address of this machine
            For details on configuring the setting, refer to [Configuring network environment settings] .
          2. Configure the E-mail address of this machine
            In the administrator mode, select [System Settings] - [Machine Setting] - [Input Machine Address], then configure the E-mail address in [E-mail Address]. For details on configuring the setting, refer to [Registering information of this machine] .
          3. Configure settings to receive E-mails on this machine
            For details on configuring the setting, refer to [Configure settings to receive E-mails on this machine] .
          4. Configure settings to print a received E-mail attachment
            For details on configuring the setting, refer to [Configure settings to print a received E-mail attachment] .
          • Synthohol
            • Mar 2016
            • 5848
            Wow, didn't know there was an accessory that did that.
            Also what if the attachment is a virus or malware?
            I'd hesitate to even think of the implications of it.
            • emujo2
              • Mar 2017
              • 1579
              That's why the output is restricted to files that are not open to including viuses..ie no MS word. E
              • B0265
                • Jan 2007
                • 718
                • HasseM
                  • Jun 2020
                  • 5
                  Well, thanks for all the concerns. But I am confident that I can make is safe. The network is not the problem. The problem is that I found this E-mail RX setting in my Bizhub C250 and I was wondering what it could be used for. if i can get it to read a mailbox and print the attachments, that would be really helpful. I would like to give a remote worker the option to print without use of a VPN. Currently email are forwarded to me, so I print them manually. So I rather have this automated in a way. Thats when I found the Email RX setting in my printer and started to wonder what it can be used for......
                  • Bix
                    • Apr 2018
                    • 1421
                    That's right, it's absurd, but printers now also have antivirus software. In reality they are now computers so we are approaching a new era.
                      • 8174
                      Can you confirm the model C250 or C250i ?
                      • emujo2
                        • Mar 2017
                        • 1579
                        Like the advice you have already been given, the machine is too old to support the LK, it will not print the attachments, and your are very unlikely to find an external mail provider that can operate without the necessary encryption protocols. (TLS/SSL/Authentication). E
