Konica Minolta Bizhub C364e Airprint
  • Alex1
    • Oct 2012
    • 287
    Hi all, I have a Konica Minolta Bizhub C364e and I want to activate Airprint on it. I have the latest firmware to install but is there a soft switch setting I need to change in service mode? Does anyone know what the setting is as I can't remember it.
    • 15068
    Re: Konica Minolta Bizhub C364e Airprint
    If I remember correctly, once the firmware is installed you just need to go into admin and then network and enable airprint
    • tsbservice
      Field tech
      • 8081
      Link sent.
      • Bix
        • Apr 2018
        • 1421
        Correct, if you downloaded the latest firmware you must enable AirPrint from the network settings.
        • copier tech
          • 8236
          Change the function version to 7
          CE mode system 2 SW25 HEX 60.
          Then enable AirPrint in admin>Network settings.
          • Alex1
            • Oct 2012
            • 287
            After I done thus I can not log in to the machines interface nor can I scan to email. I changed the hex settings to 50 for SW25 rather then 60 does this effect it in anyway
            • Synthohol
              Certified Konica Expert
              • 5922
              60 not 70, not 50.
              • Alex1
                • Oct 2012
                • 287
                Originally posted by Synthohol
                60 not 70, not 50.
                Sorry I meant 60. I'll try it again.
                • Synthohol
                  • 5922
                  what model shows on top of a printed network configuration page?
                  • Alex1
                    • Oct 2012
                    • 287
                    I'm doing this remotely so I am unable to print out the sheet. But it worked it logged in thanks for the help.
