Bizhub C308 C368 error code C-D011
  • radd
    • Jun 2020
    • 63
    I have just had this code on 2 machines, if I have read correctly I need to update 2 firmware files, 1 preventative if the error has
    not yet shown and the other if its has and not needed if the SATA has a firmware ending 4.
    Are these the current firmwares needed:
    A7PU0Y0-F000-GXX-A8
    A7PU0Y0-F000-GXX-B0
    Are they the same for both the 308 and 368, could I get them here.
  • tsbservice
    Field tech
    • 8020
    Re: Bizhub C308 C368 error code C-D011
    Correct you will need recovery A8 FW if they error out. I may have it for you tomorrow. And yes both machines use the same firmware.
    You seem to be on good track now. Keep it up.
    • Synthohol
      Certified Konica Expert
      • 5847
      PM sent
      • karel
        • Mar 2018
        • 44
        Dropbox - TNEU1600101EN_3.5.pdf - Simplify your life
        • radd
          • Jun 2020
          • 63
          Thank you both very much!!!
          Appreciate all the help
          Will do my best to stay on track
          • radd
            • Jun 2020
            • 63
            Already got them, thanks
            • karel
              • Mar 2018
              • 44
              I worked this problem a long time ago. I uploaded the corrections, unfortunately C-D011 returned after three months - the machine went to parts.
              • radd
                • Jun 2020
                • 63
                Hopefully I will have better luck, these machines have just been refurbished ( or so they say )
                Find out tomorrow
                • Bix
                  • Apr 2018
                  • 1421
                  Hey! I also have a C364e with a CD050 which I was unable to solve. Does the technical module also apply to this model? The only way to solve this is to disable HDD. I have already replaced HDD but without success. Occasionally returns CD011. I was even thinking of replacing MFPB. This printer is in my lab, so I haven't really investigated how to fix it.
                  • karel
                    • Mar 2018
                    • 44
                    Bix try A5C10Y0-F000-GDC-M1.exe
                    • avecosat
                      • Jun 2012
                      • 305
                      The only way is to change the MFPB with the firmware the problem returns
                      • radd
                        • Jun 2020
                        • 63
                        Just to update:
                        I restarted my 2 machines with the C-D011 error today, when I did neither one showed the error
                        so quick as I could I installed the GXX-B0 ( to update the SATA firmware )
                        so far so good been running all day, fingers crossed
                        • Copier repairman
                          • Aug 2019
                          • 86
                          will need the following files
                          You can help me.
                          canonrp@naver.com
                          jabattgg@gmail.com
                          Recovery Tool firmware
                          A7PU0Y0-F000-GXX-A8
                          Preventive firmware
                          A7PU0Y0-F000-GXX-B0
                          USB-BOOT firmware
                          A7PU0Y0-F000-GG3-54
                          USB-FW firmware
                          A7PU0Y0-F000-GC3-54
                          USB-SATA firmware
                          A7PU0Y0-F000-GXX-A6
                          • Zesti
                            • Jun 2009
                            • 308
                            Just for an exprt advise on D011...got this D011 call from customer on C368. The fault was intermitent and randomly. I was in field so vsited the customer and turned off hdd. Worked fine since last week. Customer complained about scanning capcity. So should go for HDD replacement or should I try FW first. I think HDD was going down...
                            • Tomas Chuah
                              • Oct 2021
                              • 3
                              My Bizhub C368 also had this code C-D011 lately,
                              I need this 2 firmware files to slove the error.
                              A7PU0Y0-F000-GXX-A8
                              A7PU0Y0-F000-GXX-B0
                              Hopefully and apprciates to help me getting this two firmware files here.
                              Thank you.
