Bizhub C308 C368 error code C-D011
  • feracampos
    • Jul 2021
    • 40
    #31
    Re: Bizhub C308 C368 error code C-D011
    Originally posted by feracampos
    Oh boy... I'm having this issue. C-D011.
    What steps I have to do to troubleshoot this?
    Thanks a lot.
    Already solved with logical format.
    Tomorrow I'll do the upgrades needed.
    Thanks.
    • feracampos
      • Jul 2021
      • 40
      #32
      Thanks.
      I was wrong, the problem come back.
      I'll update this topic when find a solution.
      • avecosat
        • Jun 2012
        • 304
        #33
        Change HD
        • feracampos
          • Jul 2021
          • 40
          #34
          Originally posted by avecosat
          Change HD
          Did you know if I put a bigger HDD the machine will recognize it?
          In my region I cannot find 320GB HDD anymore.
          Thanks.
          • femaster
            • May 2011
            • 1485
            #35
            Thanks.
            In a pinch I've used smaller (250GB) HDD, taken from an old 3-series copier, and it worked fine. I can't say for sure if a larger drive will work or not.
            • tsbservice
              Field tech
              • 7990
              #36
              Thanks.
              I think machine will format and use only needed space but you really have to give it a try as I can't guarantee.
              • feracampos
                • Jul 2021
                • 40
                #37
                I'll try and let you guys know what happens when done.
                • Albonline
                  • Sep 2008
                  • 1145
                  #38
                  I've used hdds ranging in size from 160 to 500 in the 4e series. i haven't played with the 8 series hdds as much, but am pretty sure it uses the same architecture as the 4e series. fdisk the drive and leave it in raw format if the copier can use the drive you will be able to format it.
                  • avecosat
                    • Jun 2012
                    • 304
                    #39
                    Thanks.
                    I use old HD from other copiers
                    • aberock
                      • May 2022
                      • 118
                      #40
                      Update SATA fw.
                      • feracampos
                        • Jul 2021
                        • 40
                        #41
                        Originally posted by aberock
                        Update SATA fw.
                        Yes, and now I'm stuck on this.
                        KM BH C308 freezes in "two towers and dot" state while attempt to do FW Update.
                        • FRANK0
                          • Mar 2023
                          • 3
                          #42
                          MUY BUENAS TARDES
                          no puedo conseguir el firmware de bizhub c368 en el mercado local no es muy fasil de conseguirlo me podrian ayudar por favor
                          gracias de ante mano
                          • copier tech
                            • 8132
                            #43
                            Originally posted by FRANK0
                            MUY BUENAS TARDES
                            Happy to supply this firmware fix.
                            Printer Firmware Download
                            • Haxxorex
                              • Dec 2023
                              • 2
                              #44
                              Hello, is there a chance to receive firmware for the Konica Minolta C368 machine, it gives me error d011. I am a Kyocera Machine Technician. Our new customer has a C368 machine and I would like to fix this problem
                              • copier tech
                                • 8132
                                #45
                                Yes, sure.
