Konica Minolta Bizhub 554e Nasty Grinding noise.
  • tsbservice
    Field tech
    • 7927
    #16
    Re: Konica Minolta Bizhub 554e Nasty Grinding noise.
    Originally posted by narellano2
    Machine side. Got it. Thanks for clearing that up. Appreciate it.
    See item 11(1-2-3-4-5) screw a
    Should pay attention how to put it back correctly.
    • narellano2
      • Jun 2020
      • 22
      #17
      [ATTACH=CONFIG]45991[/ATTACH]
      I was able to get that chute off and it was packed tightly with toner, cleaned it out and seems to be running again with no grinding.
      Thanks for all the help.
      • srvctec
        Former KM Senior Tech
        • Oct 2009
        • 827
        #18
        Might have been caused by an incorrectly installed or defective waste toner box. Maybe it was installed in such a manner as to not engage the shutter to open the chute and allow toner to fall into the waste box. I've seen it happen more than once over the years on various models.
        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          Synth is a GREAT tech... he gave you two things to address .. I guess you'll remember this the next time... It'll save you time - money - aggravation.
          Glad to hear you got it fixed.
          • narellano2
            • Jun 2020
            • 22
            #20
            Oh good to know. what about if the transfer belt wasn't installed properly? Because pretty much around that same time I switched it out; that's when the issues started. I'm thinking it wasn't flush when I first installed it.
            • narellano2
              • Jun 2020
              • 22
              #21
              Yes, I am glad i opened a thread on this site. You have all been great.
              learning a lot about these machines
              Thank you
              • femaster
                • May 2011
                • 1469
                #22
                If the chute was plugged, your problem is most likely resolved. About the only other thing I can think of that I have seen is if the tab on the shutter for the transfer belt cleaning unit is broken off, the shutter won't open when you install the belt. The toner will eventually build up in the cleaning unit leading to the same grinding noise and problem you had.
                • tech51
                  • 846
                  #23
