Search Error Codes
  • tylardurden
    • Aug 2018
    • 7
    Search Error Codes
    Greetings,
    Is there any website where you can search error codes for all copier manufacturers easily? Preferably mobile friendly.
    I'm a service manager that supports multiple lines of copiers and I need a platform for my techs to easily search error messages.
    Any help would be greatly appreciated.
    Thanks,
  • JR2ALTA
    • Feb 2010
    • 2017
    Re: Search Error Codes
    a google trick is
    site:copytechnet.com "search for code in these quotes but you don't need the quotation marks"
    • tylardurden
      • Aug 2018
      • 7
      Originally posted by JR2ALTA
      a google trick is
      Yeah that’s what we’ve been doing but then you end up going down the google rabbit hole.
      While down the Google hole, I ran across this site Search Error Codes
      Seems very useful and I line the top error codes feature.
      • qbert69
        • Mar 2013
        • 1152
        Originally posted by tylardurden
        Greetings,
        Thanks,
        Here's my "Go To"!!![emoji41][emoji1303]
        Sent from my SM-N950U1 using Tapatalk
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • femaster
          • May 2011
          • 1417
          Greetings,
          That's the one right there... Been making use of their Error Code area for a number of years now. Quick and easy look up, definitely beats sifting through the service manual. I know in the Konica Minolta area, for the newer models within the last couple years, they have been starting to include jam codes as well, not just the service codes. Very handy!
          • tylardurden
            • Aug 2018
            • 7
            Thanks guys but I prefer the search feature and top searches on searcherrorcodes.com
            Its also more mobile friendly.
            • tsbservice
              Field tech
              • 7635
              This is working very good, agree.
              Sounds like you're doing some sort of advertising here
                • 2621
                a google trick is
                This hack is not mobile friendly, a bit geeky, and if you dont know what windows file extensions are stop reading here.
                This saves you typing "site:copytechnet.com" every time.
                How about a file on your desktop that you double click and this pops up, you enter your error code and you get the same results as your suggestion.
                Create a new text file, copy and paste the following and save it as whatever you like but the file extension has to be .bat
                @echo off
                set "google=http://www.google.com/search?q="
                set "site=+site:http%%3A%%2F%%2Fwww.copytechnet.com%%2 Fforums%%2F"
                set /p "string=Search Copytechnet for : "
                set "string=%string: =+%"
                start "" %google%%string%%site%
                Copytechnet search tool v0.8 Final
                • copier tech
                  • 7934
                  Greetings,
                  Thanks,
                  This is the site I use
                  • Bix
                    • Apr 2018
                    • 1421
                    Service manual on windows tablet: control + F and look for the code.
                    • fatduke
                      • Jun 2020
                      • 75
                      For me
                      https://printcopy.info/
                      is the best!
                      Cheers :-)
                      • rrrohan
                        • Sep 2011
                        • 1971
                        Wonder how secure the scan to email test is esp when providing credentials
                        Sent from my Nokia 7 plus using Tapatalk
