split vertical / horizontal lines on prints and copy documents.
  • pety
    • Jul 2020
    • 4
    Konica Minolta c280 gave a d1 error and after that,it prints split horizontal lines and copy's with vertical lines at equal distances across the document.I would appreciated if I could be helped with a solution to this error thanks.please I attached a copy of the documents.
  • tsbservice
    Field tech
    • 7980
    Re: split vertical / horizontal lines on prints and copy documents.
    Looks liks PH unit(Laser) failure.
      • 22999
      Maybe a dusty polygon mirror? =^..^=
      • tsbservice
        Field tech
        • 7980
        Blackcat honestly I dunno. Dusty poly usually appears as uneven(low) density.
        Cleaning PH unit may be a variant.
        • pety
          • Jul 2020
          • 4
          I did add a code error, it gave a d1 error.
          Consulted the manual and followed the procedure to clean set the ADF and still the problem persist.would be checking the polygon mirrow by tomorrow as suggested by some great individuals from the group. Thanks I do appreciate.
          • pety
            • Jul 2020
            • 4
            OK thanks would try that and give a feedback
            • fatduke
              • Jun 2020
              • 75
              maybe a DEVELOPER BLACK UNIT failure, did you check it's status?
              Tried on other colours? I'm talking 'bout sample page.
              Drum status?
              Cheers
              • Blizzoo
                • Aug 2013
                • 607
                Aren't those lines the 'Security patterns' that occurs after improper machine setup/NVRAM issues? This is what I can remember seeing that but I might be wrong... been a while since I worked on KM
                • rrrohan
                  • Sep 2011
                  • 1977
                  almost look like lines of shame due to bad run up
                    • 22999
                    The lines of shame are usually cyan or magenta, AFAIK never black. =^..^=
                    • rrrohan
                      • Sep 2011
                      • 1977
                      if im reading it correctly and this is only on copy not print and OP can confirm it also scans with these lines its must be a CIS issue surely and nothing to do with Laser Print Head
                      • pety
                        • Jul 2020
                        • 4
                        It occurs on both print and copy.we have been on it all day we have finally decided to change the printer board.
                        Thanks for your contribution
                        • allan
                          RTFM!!
                          • 5462
                          Bad ram on the MFPB would be my guess.
                          Seen some guys have luck replacing the ram chips.
                          Whatever
                          • srvctec
                            Former KM Senior Tech
                            • Oct 2009
                            • 827
                            Also my guess. Had some Di250 series back in the day and other random machines over the years do something very similar and it was memory that caused it.
                            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
