Bizhub C364 Can no longer access
  • carmad
    • Jul 2020
    • 7
    I have a user here to decided to try to give our printer a static IP address, now we can't connect to it, Printer shows no IP address, light is flashing amber. When I go into administrator settings, Network settings button is not there! Help please I am pulling out my hair
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Re: Bizhub C364 Can no longer access
    Have you had any lightning storms? Reason I asked is always have a few machines with this symptom during the summer months.
    You can initialize the machine in service mode and re-input settings.
    Also while in service mode make sure HDD is installed.
    As last resort you could try resetting MFP board with reset firmware.
    • carmad
      • Jul 2020
      • 7
      move tried to go into service mode to reset but it only allows me to reset fax/scan and copy settings
      • carmad
        • Jul 2020
        • 7
        I tried to go into service mode and there are no network reset options just fax/scan and copy reset... I should mention we purchased this second hand and did not to a factory reset either so not sure why so many options are missing
        • copyman
          Owner / Technician
          • Sep 2005
          • 4765
          when in service mode did you see if HDD was installed? System 2.
          Also take left rear cover off and see if HDD is there and connected
          • Bix
            • Apr 2018
            • 1421
            Hi, theoretically you should find this.
            Initialize the network settings. If you purchased a second hand printer, you should completely initialize it and check for HDD (some eliminate it at the end of the contract for privacy reasons).
            • fatduke
              • Jun 2020
              • 75
              Hey man!
              Same issue for installing "Scan to..." after HDD format.
              Check if HDD is installed in Service Mode.
              Cheers!
              • allan
                RTFM!!
                • 5462
                Make sure the network cable is unplugged during this.
                Check if there is a message on the screen showing ARP request.
                Link and act lights active?
                Whatever
                • copier tech
                  • 8200
                  Shut the machine down, unplug the LAN cable power machine back on & wait 5-10 minutes, leave LAN disconnected & go back & check network settings.
                  • rrrohan
                    • Sep 2011
                    • 1977
                    i dont know why arp requests take so long on a KM. on a HP if you plug in you get a IP within like 15 seconds, similarly if you unploug you also lose the IP very quickly and get a 169 address
                    • carmad
                      • Jul 2020
                      • 7
                      [ATTACH=CONFIG]46123[/ATTACH]
                      This worked, I can finally get into my interface and it now has an IP address. Yes there is a hard drive.... BUT now I am getting this error with orange light blinking "No Animation Guide Data" Any ideas?
                      • carmad
                        • Jul 2020
                        • 7
                        Yes HDD is installed but now getting "No Animation Guide Available" with flashing orange light
                        • Bix
                          • Apr 2018
                          • 1421
                          Hi, once the HDD is installed again you must insert the MOVIE DATA. Is the model a Bizhub C364 or C364e correct? This way someone can send it to you privately
                          • carmad
                            • Jul 2020
                            • 7
                            It's the C364, I may need clarification inserting movie data.
                            • Bix
                              • Apr 2018
                              • 1421
                              Soon I will send you pm
