Develop 284E Konica minolta C284
  • Gab
    • Aug 2015
    • 676
    MAchines makes about 7-8 copies and error C2558. Toner is compatible but used many times on this machine.
    Isz the toner, toner chip or something else?
  • Bix
    • Apr 2018
    • 1421
    Re: Develop 284E Konica minolta C284
    Hi, compatible toners can always go well but sometimes, for some reason, its can make you lose a lot of money.
    The error refers to: Abnormally high toner density detected black TCR sensor.
    Try to dismantle the development unit and check its condition.
    • copier tech
      • 8200
      This is the issue with compatible each bottle is not identical occasionally you get one with too much toner v developer etc.
      Take the toner bottle out & run full gradation prints, this will bring the level back to normal around 6% (the same as the remaining colours)
      Then run initialise+stabilisation refit the toner & check level stays around 6%
      • copyman
        Owner / Technician
        • Sep 2005
        • 4765
        Only takes 1 bad toner. As discussed on this forum many times it's just not worth using aftermarket toners. If it crashes a developer unit it can be expensive!
        If it wasn't aftermarket toner I would say to take toner out and and shake 20 times side to side to loosen up toner inside, you can try this but could be many things with bad toner.
        • emujo2
          • Mar 2017
          • 1579
          This guy has more red cards than anyone I've seen..Who did he piss off and why? Looks like he contributes nothing (not speaking of money). E
          • copier tech
            • 8200
