Bizhub c3350 scan settings anyone?
  • mrfuser
    • 1617
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Bizhub c3350 scan settings anyone?
    Originally posted by mrfuser
    I have a client with a couple of okder c3350 units that they are needing it to scan default black and white and for the life of us we can’t see a way to do that. Most bizhubs you can change the settings on scan screen then go to user tools and set as current settings. Doesn’t seem to be the case here and can’t do it via web interface either.
    any thoughts?
    What if you set a program to default B/W and then choose that program as the one-touch via the web interface?
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • femaster
      • May 2011
      • 1482
      According to the User Guide, it is done just as you describe, same as any of the other models:
      [Default Scan Settings]
      To display: [Utility] - [User Settings] - [Scan/Fax Settings] - [Default Scan Settings]
      Change the default settings (settings when the power is turned on, and the Reset is pressed) in Scan to E-
      mail or Scan to Folder mode.
      You can change the setting by selecting [Current Setting] after settings in Scan to E-mail or Scan to Folder
      mode have been changed.
      [Factory Default] is specified by default.
