Konica c284 copies with problems
  • enricocopyline
    • Jun 2018
    • 129
    Good morning
    I have a konica c284 that works very well in printing but in copy of from problems and it copies me as in attached images. bottom in copies
    I have already replaced the main board but I have not solved the problem
    What could it be?
    SKMBT_C28420071310430_0001.jpgSKMBT_C28420071310430_0002.jpgSKMBT_C28420071310430_0003.jpg
  • copier tech
    • 8236
    Re: Konica c284 copies with problems
    Originally posted by enricocopyline
    Good morning
    What could it be?
    [ATTACH=CONFIG]46186[/ATTACH][ATTACH=CONFIG]46185[/ATTACH][ATTACH=CONFIG]46184[/ATTACH]
    What exactly is the issue, it's not easy to see from your samples?
    But you replaced the main board for a quality fault is that right?
    • enricocopyline
      • Jun 2018
      • 129
      unfortunately you do not see it but it is the bottom of the whole copy and bad photocopy
      • copier tech
        • 8236
        Post a sample of the gradation test prints in CE mode.
        It maybe the print quality is poor but when you take a copy makes it look worse.
        • Toxic
          • 698
          Bit strange to replace board because quality issue...
          Did you check drums,developing,tr.belt, clean scanner...etc before replace main board?
          And it is never good to test copy this machine internal test print.
          • enricocopyline
            • Jun 2018
            • 129
            gradatione test it's ok
            perhaps the problem is better seen here
            GRAD.pdfPROBLEM.pdf
            • copier tech
              • 8236
              [ATTACH]46190[/ATTACH][ATTACH]46189[/ATTACH]
              OK so the gradations look good.
              Are the test pattens BOTH a copy?
                ok i'll ask the question that you failed to answer..
                why replace a board when it is clearly a hardware issue?
                look at the ITB and drums.
                what are the page counts on supplies/PM parts?
                • enricocopyline
                  • Jun 2018
                  • 129
                  I changed the card to make an attempt to understand what it could have been
                  itb and drums are good
                  if they weren't good you could see some problems even in the press
                  and not just in copy and scan
                  test pattern are print.
                  the problem does it even by doing a scan it is not a consumable problem.
                  • emujo2
                    • Mar 2017
                    • 1579
                    PCQ can be caused by electronics..Scanner and printer boards can contribute..However, the fact that he wants us to help him based on PDFs that, according to him, don't show the problem, is what I can't get past. E
                    • tsbservice
                      Field tech
                      • 8080
                      Maybe the wavy bird chart is your problem? Does it do this from both DF and scan glass?
                      • enricocopyline
                        • Jun 2018
                        • 129
                        Maybe I did not say it clear enough
                        this is the problem (PROBLEM pdf) and it does it both in scan and in copy from DF and from scan glass
                        in print it works very well
                        PROBLEM.pdf
                        • Albonline
                          • Sep 2008
                          • 1154
                          IF this happens only on scanning/copying. reseat all optical connections ck for bent scanner unit, clean everything in the optics area look to see if ccd has been moved.clean added ram connections.replace ccd.
                          • tsbservice
                            Field tech
                            • 8080
                            Looks digital agree. Common problem on these is front left corner of the scanner unit bent during transportation or by customers. Give it a tug upwards and check the image again. Exchange RAM modules with another working. Let us know.
                            • tsbservice
                              Field tech
                              • 8080
                              To check image just copy blank A4 sheet. I believe it will have those bands of greenish stripes on copy.
                              Tug scanner and make another copy if stripes became less you know you're on right track. Tweak it until your copy is blank as original. Next do it with A3 paper. If you're lucky that may solve your problem.
