Flashing Op panel on Bizhub 3320
  • SAR
    • Jul 2009
    • 203
    The entire Op panel assembly has been replaced so far and all board connectors reseated. The machine is functional, but the op panel is un usable, it just flashes.
  • Synthohol
    Certified Konica Expert
    • 5807
    Re: Flashing Op panel on Bizhub 3320
    if it did it before the panel replacement i would think cable or the board its connected to. even its ssd maybe.
    does it also flash if booted in some service mode?
    ck power supply for 24 and 3.3/5v
    • rrrohan
      • Sep 2011
      • 1976
      flashes alive then blank?
      ive had a 4 series with flashing main menu after a dodgy firmware update
      • SAR
        • Jul 2009
        • 203
        Thank you for the replies! Sorry to say I don't have an answer for this one.
        The customer decided to just upgrade the machine, which worked out best for everyone.
        • tsbservice
          Field tech
          • 7986
          Little POS, good decision.
