Request bizhub c220 firmware
    • 8174
    #31
    Re: Request bizhub c220 firmware
    Originally posted by bumbum26
    Hello from Germany,
    i know it is my first post and my englich is not the yellow of the egg :-)
    I become from my chef an bizhub c220 and the drum unit is end of life.
    before i buy a new one, i will check the machine has more then this problem.
    now i read with a firmwareupdate i can disable drum unit check.
    is this right?
    have anyone this firmware?
    thank you
    Happy to help with the firmware & reset instructions.
    We can supply most major manufacturers printer & photocopier firmware. Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware
      Originally posted by TryToCopy
      Actually I didn't Initialize All in System 1, I'm pretty sure that I've made a rookie mistake at some other point, but thats maybe because of I'm a rookie with Konica Minolta bizhub printers?
      Everything I did sounded reasonable for me, but clearly something went a way not intended.
      I'm very happy that out there are people like Phil B. who really trys to help without being that kind of offensive...
      What's your contribution to solve this problem with a statement like:
      If you clearly have no idea how much time i spent trying to fix the machine?
      Suggest you go easy on senior techs here.
      Snarky 'tudes will earn you red cards.
      • emujo2
        • Mar 2017
        • 1579
        #33
        Hello from Germany,
        is this right?
        thank you
        Here's my 2 cents..This firmware is for techs that wanted their customers to stop calling in and demanding a replacement drum/IU/fuser ect when the message came on. Many of these items ran well past their stated life..just let the message display and change the item when you have a copy quality issue..
          • 8174
          #34
          Exactly, not only does this this save the tech/company money it keeps the client happy & less waste going into landfill.
          • Metasfrastiki
            • Mar 2022
            • 4
            #35
            Hello from Greece,
            I recently change the main board in my Konica Minolta BizHub C220 and after that it gave me a error C164.
            If somebody can send me the Firmware i would be grateful!!!
              • 8174
              #36
              Originally posted by Metasfrastiki
              Hello from Greece,
              Happy to help drop us an email
              Printer & Copier Firmware - www.printerfirmware.co.uk
              • Metasfrastiki
                • Mar 2022
                • 4
                #37
                mike.zotos@gmail.com
